MXA-MP/MPL use?
rrdbstudios
in AMX Hardware
I have 3 MXA-MPL's and am just sending a single feed in and trying to get a single stream out.
Problem is there is a lack of documentation as to how to configure them; there is a module for an example for use with the enova switcher and 10 sources to cycle through, but I only need one.
Can anyone shed some light on how to get these up and running quickly. I have them connected properly to the best of my knowledge and the mxt-1000's see them but all say not streaming; also firmware is up to date.
http://www.amx.com/techsupport/techNote.asp?id=1007
for an explanation of MPL setup with an X-Series panel for the simple case. Follow up if you are still having problems.
Turns out, all 3 of my will not update their firmware and are heading back to AMX... Not sure if it was just the firmware I was coming from .. 1.1.82
Simple case like that working with no problem. But I have no idea how make a preview more than one picture? Can you help with it?
