Home Duet/Cafe Duet
Java Time Issues
Anybody ever deal with UTC time in Duet? It is my understanding that my PC and AMX master both synced to network time should have very similar values for "Date.getTime()" and "System.currentTimeMillis()", as both should be a count of the number of milliseconds elapsed since Jan 1 1970. Displayable time would then be calculated via a TimeZone offset. My Date.getTime() value differs by 5 hours or more, currentTimeMillis by about 3 hours. (Both depend on wether you use integer math or not). Anybody know what is going on? I am trying to generate time stamps on a PC (in Java) and use them in Duet, not sure about using an arbitrary offset because not sure what timezones this might be used in.
  • GregGGregG Posts: 251
    I ran into a problem a while back where the internal hardware clock in netlinx is set to local time (like windows does), but the library functions in java expect the hardware clock to be set as utc.
    http://www.amxforums.com/showthread.php?5176-Something-up-with-the-Date()-functions-in-Duet
    Maybe they haven't found a work-around for it yet?
  • AMXJeffAMXJeff Posts: 450
    GregG wrote: »
    They have not fixed it yet, reported it again recently. The fix is easy, you just set the time zone to UTC in the JVM startup system properties. But first they have to agree its a bug, than they have to want to fix it. Oh well...
