ICSP Port Assignments
in AMX Hardware
In the "NetLinxControllers.WebConsole-ProgrammingGuide" in the "Terminal (Program Port/Telnet) Commands" section, right after the "PC COM Port Communication Settings" it shows:
Anybody know what it's talking about?
NetLinx Integrated Controllers - Port Assignments
Each of the NetLinx Integrated Controllers has specific port assignments:---------------------------------- ---------------------------------- |NI-700 Port Assignments | |NI-900 Port Assignments | |--------------------------------| |--------------------------------| |Port |ICSP Port # | |Port |ICSP Port # | |--------------------------------| |--------------------------------| |Serial Port #1 |1 | |Serial Port #1 |1 | |Serial Port #2 |2 | |IR/Serial Port #1 |2 | |IR/Serial Port |3 | |IR/Serial Port #2 |3 | |I/O Port |4 | |IR/Serial Port #3 |3 | |IR RX Port |5 | |I/O Port |4 | ---------------------------------- |IR RX Port |5 | ----------------------------------
I always hate how AMX port numbers jump around from one processor to the next.
Would life be easier if the first IR port were the same number on every processor, no matter how many serial ports it might have? Same for relays, IO ports?
Yes, it would. You could interchange processors without recoding/reconfiguring.
</rant>
+1
Yes, yes it would.
Perhaps, but I still find it fairly easy to deal with:
Extend and expand to suit your style/needs. Doesn't work when referencing ports on other systems using M2M obviously, but there are ways to achieve this too.
There are plenty of other things more rant worthy than this.
I think that all of those devices are on the ICSP buss and that those are their port assignments/addresses. That's how I've always viewed it.
