NI-3000 cannot be connected
Metso
in AMX Hardware
Hi,
We have a NI-3000 which cannot be connected via ip or rs-port. We checked the Conf. dips / baud rate.
After power up all the port leds run their cycle as normally, but after that both the status and input leds just stay permanently on.
CR10 flashes on the pcb. Removing the flash card has no change. We took another flash card from a working NI-3000, but no change.
The sno. is 210502X01180003, ICSNET installed.
Best regards,
Markku Metsovuori
AV-systems Oy
Best regards,
Markku Metsovuori
AV-systems Oy
cheers
Actually no, it doesn't sound like the bias voltage cap on the Serial port that kills serial control but leaves the netlinx otherwise completely functioning....
Thank you for insightful reply, I'll ensure I do not offer any suggestions ever again
yours humbly
Baldrick
Overreact much?
I think your diagnosis was off, but if that upsets you.... why?
I tried this, but no change... I guess it is RMA time.
I think I remember the capacitor issue being a lower flat rate repair, but I could be way off.
Regardless, I agree with the above now that I think about it. Didn't realize used AMX gear was so cheap these days. According to eBay, I'll have to pay someone to take my like-new condition MVP-8400!
Thanks for the clarification!
