Clearone SR1212 ADPRESENT command
Hi,
Does anybody have any experience with the ClearOne SR1212 ADPRESENT command? I'm receiving responses from the SR1212 but what I'm receiving is different from what the manual is saying I should.
Here are 3 responses back from the SR1212
#G3 ADPRESENT 0 6 0 0 0$0D$0AOK>
#G3 ADPRESENT 0 E 0 0 0$0D$0AOK>
#G3 ADPRESENT 0 FEF 0 0 0$0D$0AOK>
The command is on page 239 of the serial control manual.
Any Thoughts?
Yours,
John Wilhelmi
Any Thoughts?
Yours,
John Wilhelmi
The ADPRESENT will report back the following:
DEVICE ADPRESENT INPUTS OUTPUTS PROCESS FADERS TELCO
EG:
Output 6 has a signal
Outputs 2,3,4 have signals
Outputs 1-4 and 6-12 have signals
Hope this helps.
Cheers
Craig
In the first statement if Hex 6 is converted back to binary, the result would turn on bits 2 &3.
for the string,
would read
Outputs 2&3 have a signal
Was there something in the math that I missed?
John
No, you are correct.
Sorry, I don't know what happened.
Cheers
