play audio stream with Modero X series TP
Aleksey
Dear professionals,
I have MXD-1000-L and MXD-430-P and I would like to play incoming audio stream from AXIS P3364-L camera.
Camera encodes sound in G711, G726 and AAC formats.
Could you suggest me how to play audio stream with touch panels?
The panels are not designed for audio streams to my knowledge. They can take video streams, and they can take SIP connections with audio, but I don't think they can do what you ask. I hope to be wrong.
I've been looking into this as well, and am convinced there is a way unless AMX deliberately blocks it for some reason. I'll let you know if I can find anything out about it.
Hope it helps..
Actually, it wasn't only my question, there are other people who want to do it.
If panel didn't have speaker I wouldn't even think to use it . But it has and there are a lot of useful advantages with audio.
I'm going to try Asterisk SIP server. Anyway we need it for VOIP. Most probably it is possible to encapsulate audio stream to SIP and route it to TP.
And as vincen said there is another one way. We can use some software(VLC, ffmpeg?) for merging audio and video streams.
But it will be easier if AMX provides a way how to play audio stream without converter.
I set 711 codec and used http://192.168.3.8/axis-cgi/audio/receive.cgi?httptype=singlepart
Also I transmited a film to panel from VLC. The motion pictures appears fine but no audio. Unfortunately, there is no 711 codec and I didn't find right plugin yet.
kHz, 22.05 kHz, 24 kHz, 32 kHz, 44.1 kHz, 48 kHz), AAC-LC (8 kHz, 96 kHz) and G.711 with μLaw (VoIP encode/decode at 8kHz) that is embedded within a video stream. On the panel side you will need to place a button and set its video fill to your resource with the audio embedded - works a treat.
So you need two buttons one for audio and one for video with slightly different resources set? If so, do they sync properly? I figured since the E-COM can do two way communication with touch panels over G.711 with μLaw then any camera that supports it should be able to as well. I haven't had the gear around to experiment but as you say, there seems to be no technological reason why it wouldn't work.
What kind of software/hardware do you use for streaming?
Check this doc - http://www.amx.com//assets/whitePapers/DigitalMediaCapabilities.ModeroXSeries.TouchPanels.WhitePaper.pdf
It's written that modero x does support mpeg2 decoding with video and audio support. AMX provides encoder with such capabilities - MAX-CSE.
We also stuck with the same issue - unfortunately have no modero x and max-CSE to test, but I assume that encoder may be replaced by software encoder.
Please share your results when you are done.
We got the same audio problem with TPC.
You can use VLC to output a udp multicast mpeg2 TS (video container: mpeg2 ts;video codec:mpeg2; audio codec: aac)
Then use the diagnose page in the Modero X to see if it work.
In diagnostic page of panel I set udp://@224.1.1.1:1234
And.. wow! It works like a charm!
Many thanks to PhreaK and jason.lim and other people who took part in the discussion.
