Sometimes could not touch a button on MXD-430
Aleksey
in AMX Hardware
If I touch 10 times a display of MXD-430 then it answers 6-7 times only.
But during Calibration procedure a cross is following my finger without any problems.
A project for TP has only one momentary button and firware was updated to latest version.
Any suggestion?
Any suggestion?
If you have a transparent image in a button don't forget to set Touch style to Bounding box.
Well, Alexsey, your question may not be that silly.
I have encountered the exact same issue with a one just recently installed. The touch sensitivity seems to be very inconsistent. It also seems to vary according to the areas on the touch surface, ie touches on the bottom and right seem to have a harder time producing a push. And I have made sure all buttons are bounding box. Even the setup pages have this tendency, so I am not suspecting my file. A second panel ordered as advance exchange produced same results.
And like you, I found the calibration page to be spot-on and much more sensitive. AMX, is there a change taking place between the "raw" panel touch sensitivity exhibited by the calibration page and that of any pages when loaded with a file?
This needs to be looked into. I'm afraid my customer will quickly become frustrated with this panel.
Again, the calibration test page seems so much more responsive that I cannot help but believe it's something that can be fixed in firmware.
While I like the swipe feature and everyone expects it nowadays I'd often like a disable button if it ain't gonna work properly so we can at least get consistent pushes.
