How to program the Clearone audio conference pop up page on AMX system
Dear All,
How to program the Clearone audio conference pop up page on AMX system? When received calls from far site, the AMX touch panel should pop up one page, then the user can select Answer or reject the call. My question is how to program the AMX system when received call then the pop up will show out. Is it possible the panel can show out the phone number when received a call from somewhere?
Thank You.
  • PhreaKPhreaK Posts: 966
    Hi Han, this is certainly possible. You'll need a bit of programming experience to implement this. If you're new to the AMX world get in touch your local AMX office and they'll be able potentially get you on the right track there.
    In addition to that the Clearone protocol manual is going to be your friend. The 'CALLERID' command in particular.
    Also, try not to cross-post. If you just pop up your question in the most relevant area of the site one of the awesome community members will tend to help you out in no time.
