Sending channel arrays to a touch panel
In the docs, it lists
CHAN[ ] – a channel array.
as an allowablet parameter to
ON[DEVICE,CHANNEL]
this works... sometimes
Anyone else ever pulled their hair out over this?
I have to set_length_array before it will update my touchpanel.
Here's a complete demo file. Just make a tp file with buttons 1 through 8.
PROGRAM_NAME='arraytest'
vdv = 33001:1:0
tp = 10001:1:0
DEFINE_CONSTANT
INTEGER BUTTONS[] = {1,2,3,4,5,6,7,8}
VOLATILE INTEGER hack
CHANNEL_EVENT[vdv,1]
    ON:{
	ON[tp,buttons] //works
CHANNEL_EVENT[vdv,2]
    ON:{
	LOCAL_VAR INTEGER i_BtnsToTurnOn[4]
	STACK_VAR INTEGER idx
	//turn them all off
	OFF[tp,BUTTONS] //works
	//turn 1st 4 on
	FOR(idx=1;idx<=4;idx++){
	    i_BtnsToTurnOn[idx] = idx
	IF(hack){
	    SET_LENGTH_ARRAY(i_BtnsToTurnOn,4)
	ON[tp,i_BtnsToTurnOn] //only work after at least 1 set_length_array
CHANNEL_EVENT[vdv,3]
    ON:{
	STACK_VAR INTEGER i_BtnsToTurnOn[4]
	//turn them all off
	OFF[tp,BUTTONS]
	//turn 1st 4 on
	IF(hack){
	ON[tp,i_BtnsToTurnOn] //need set_length_array (stack_var)
    a_riot42a_riot42 Posts: 1,624
    I use this all the time, but its not surprising that you need to use set_length_array. Whenever you decide to manually edit arrays on your own, Netlinx doesn't keep track so its up to you to set the length. You could do this using other methods which wouldn't require it though.
    a_riot42 wrote: »
    As a rule-of-thumb, if there is a built-in function to manipulate the array (like any of the string functions), the length is set properly. If you manually change any of the elements, you have to set the length yourself. I can't think of any exceptions to this, but it wouldn't surprise me if there were a few odd cases.
    DHawthorne wrote: »
    I think the only exception is when using double quotes to concatenate a string. Netlinx must sum the characters in each string and set the length of the new string to that length. I've never actually tested it but I never use set_length_array when using double quotes and I still get the correct result.
    Another way to say it:
    The length will not change if you set/poke individual cells in the array.
    The length will change with any other type of assignment.
    travistravis Posts: 180
    But this is just poking individual cells...
    travis wrote: »
    Which is why the length will not change…
    Am I missing your point?
