"Transfer Aborted - Unknown reason" on IR file xfer to NXI
Another helpful diagnostic message from AMX.
I've successfully uploaded to this before and have no idea what's happening but I can't get past this error. I tried several different files, concerned that the IR file was corrupt, but nothing works. It's a file I'm trying to get into ports 8 and 9 of an NXI as 5003:8:0 and 5003:9:0.
Does anyone have any experience or insight?
I can xfer the same IR file to an IR port on the NI4k and on a different NXI w/ no problem, but I get that error on that NXI. It's mapped to 5003:8:0.
That particular NXI appears to be working fine otherwise.
The most common error I make is having the IP address or system number incorrect.
As it is device number 5003 I am guessing it is a slave device, I always do master to master so don't know if there are any special considerations of uploading IR to slave devices. Maybe you are connecting to the slave device when you should be going via the master.
Have you tried "Get Available Memory" to see if you can talk to the IR port at all?
I've checked all the fields and tried using system 1 instead of 0. No dice.
One other note: during the file send, I always lose connection from NL Studio to the master.
It shows 199 of 9089 bytes transferred. I've tried sending other files to the NI4K ports just to test if I had hit some capacity constraint, but they transfer fine.
John - what do you mean by "get available memory?"
On older units like the NXI, there is shared memory across several IR ports. You can't exceed the capacity, or you get cut off. The button asks how much room is available. It if is close to used up, you can't upload.
Note that on NEWER units, like the 3100 with modern firmware, the button will always return 32,000 or something like that. It still does indicate that you are talking to an IR port; any other port or a bad port will time out.
I usually xfer via NL Studio. I tried using IREdit on my Win XP SP3 machine to do get avail memory. It shows 32768 bytes.
When I send from IREdit, IREdit crashes. So frustrating...
Nonsense. This poster has no idea what he's saying, and has littered many threads today with random comments. He may think he is helping.
EDIT: Looks like all the silly posts by this new member have been deleted. They certainly didn't look like contributions.
