Home AMX Technical Discussion
TIMER for electrical floor heating
Hello guys.
i need to use a timer for controlling electrical floor heating.
I need the heating to run 30 min, 30 min break, run 30 min, 30 min break and so on, as long as the client wants.
i don't know how to program a timer.
i was thinking to use something like this :
while heat_desire=1 and heater_on and 30 min have not past, keep the heating running
if 30 min have past, stop heating for 30 min.
this cycle must repeat forever
    Make a timeline with two events, your on and off. Set the increments to your 30 minute interval, create the timeline when your device controller comes online, and set it to repeat. Particulars are in the NS help under timelines.
    Here is an example using a couple of WAITs. You can also do as Dave suggested and use TIMELINEs instead.
    dvTP = 10001:1:0
    // we'll setup 2 different wait times so we can adjust the modulation if need be
    VOLATILE INTEGER nHeatCycleOnTime 	= 18000 // 30 minute
    VOLATILE INTEGER nHeatCycleOffTime	= 18000 // 30 minute
    VOLATILE INTEGER nHeatCycleEnable	// 1 = heat cycle is enabled
    DEFINE_FUNCTION fnHeatOn() {
       // do whatever to turn the heat on
    DEFINE_FUNCTION fnHeatOff() {
       // do whatever to turn the heat off
    DEFINE_FUNCTION fnHeatCycleOn() {
       fnCancelHeatWaits()
       fnHeatOn()
       IF (nHeatCycleEnable) {
          WAIT nHeatCycleOnTime 'HEAT OFF' {
    	 fnHeatCycleOff()
    DEFINE_FUNCTION fnHeatCycleOff() {
       fnCancelHeatWaits()
       fnHeatOff()
          WAIT nHeatCycleOffTime 'HEAT ON' {
    	 fnHeatCycleOn()
    DEFINE_FUNCTION fnCancelHeatWaits() {
       CANCEL_WAIT 'HEAT ON'
       CANCEL_WAIT 'HEAT OFF'
    BUTTON_EVENT[dvTP,1] { // heat cycle enable/disable
       PUSH: {
          nHeatCycleEnable = !nHeatCycleEnable
    	 fnHeatCycleOn()
          ELSE {
    	 fnCancelHeatWaits()
          [dvTP,1] = nHeatCycleEnable
    cristibad wrote: »
    Hello guys.
    Why does he what to do this, did they forget the slab sensor or they didn't put a t-stat in to control it? If he really needs this then you might what to make the on and off timers variable so he can adjust from the TP as needed to achieve a comfortable floor temp. 15 on 15 off or maybe 10 on 20 off otherwise if you make it hard coded with out the ability for the user to adjust you may have to modify the waits or timelines multiple times before he gets it where he will ultimately be happy with it and that may change seasonally.
