Power Tracking on IR without Discretes
Hi All,
I am wondering what the best method is to track if an IR device is already on.
EXAMPLE:
I have selected source XBOX and tv turns on (and matrix, amp, etc) later I select Bluray (matrix, amp, etc do there stuff) but the tv turns off because the Power command is being reissued.
The TV in question does not have discrete codes (i have contacted the manufacturer). I have thought of using functions but I am not quite sure what the best method is.
EXAMPLE:
AMX have the video sync sensor http://www.amx.com/products/VSS2.asp that is able to detect a video signal (ie, the Video Out connector on the device you are controlling), or the http://www.amx.com/products/PCS2.asp a 110V power current sensor that apparently is able to detect whether a device is in On or Standby modes.
DEFINE_CONSTANT INCLUDE 'SNAPI' DEFINE_VARIABLE INTEGER nZ1TVPowerStatus = 0; // 0 = off, 1 = on DEFINE_FUNCTION PowerStatSend(CHAR sCmd[]){ IF(nZ1TVPowerStatus) //Send String to Matrix ELSE { BUTTON_EVENT[dvTPSD,166] { PUSH: { PULSE[dvSoniqTV,sqPower] } } } } DEFINE_FUNCTION Power OnCan some check if i am on the right idea
For instance Panasonic screens will switch on if you press a numeric digit on the remote. Therefore, you are pretty nearly always right to assume the screen is on after firing that IR digit cmd.
From there all you need is a small function to force it back to your AV mode. The Panas can actually accept this source change before you see or hear anything from the FTA (from the power off state) making it almost unkown to the end user you've gone via TV mode first.
It can be a little messy (read: time consuming) when going from say av 1 to 2 when it's already on - in that for you to be sure you're on, you will need to fire the digit 1 at it first etc...
It's a bit of overhead for sure and may even score you a flash of FTA now and then depending on the screen, but it's generally ok for most people and a small price to pay for resolving the 'power on sync issue'....and, it's done in code.
Test your screen by firing every button but power at it whilst it's off to see if it powers up...
As mentioned by others already the only 1000% sureity is hardware, however, this method runs a pretty good second place in my experience...
Sensors: current, magnetic, video, audio, contact closure, ac/dc voltage (discontinued led/light).
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/CBCSM1/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/CSM1/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/SMMAG01/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/SMVID01/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/SMAUD01/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/SMCC01/
http://www.xantech.com/Controls/ControllersSwitches/ControllersSwitchers/SMVLT01/
There was also a SMLIT01 led/lighting sensor which they seem to have discontinued for some reason and of course that's the one I've used the most.
