Old Lutron before Intercative Module
I am looking for any help with a possible module for the old Lutron Homeworks System, before interactive or Illumination. I got a protocol from Lutron, but I am wondering if anyone have a module for it. I have the task to integrate this old Lutron System with Netlinx, but of course our sales team didn't sell enough hours for me to try to create a module for it. Lutron provided the attached protocol. I am just wondering if anybody out there has a module for it or sample code. The button emulation is very straight forward, but the LED feedback is very tricky.
Ricardo
Ricardo
Yes please send it to me. It will save me a lot of time trying to come up with something for a job undersold. I appreciate your help very much.
Ricardo
Thanks true for sending me your module. Now, I am trying to see if I can do the LED Feedback. Do you guys know how to covert a HEX number to bits and store it on an array? Here is a sample of a probable LED feedback string:
'L101A2BD',$0D,$0A
L1 = LED feedback for panel 1
01 = Keypad 1
A = HEX value for LED 13 to 16 - 1010 (LED 13 is On, 14 Off, 15 On and 16 Off)
2 = HEX value for LED 9 to 12 - 0010 (LED 9 is Off, 10 Off, 11 On, 12 Off)
B = HEX value for LED 5 to 8 - 1011 (LED 5 is On, 6 Off, 7 On, 8 On)
D = HEX value for LED 1 to 4 - 1101 (LED 1 is On, 2 On, 3 Off, 4 On)
The ideal would be to be able to store this on a structure or array that we could hold the PANEL, KEYPAD and all LEDS, so we could assign a TP channel # to the LED current status of 1 or 0.
Something like: [Panel][Keypad][0000000000000000]
Any ideas?
DEFINE_DEVICE //PORT 3 used for Lutron///////////////////////////////////////////////// dvTP_Lutron1 = 10001:3:0 // Real Panel (dviPad_GreatRoom) dvTP_Lutron2 = 10002:3:0 // Real Panel (dviPad_Master) dvTP_Lutron3 = 10003:3:0 // Real Panel (dviPad_Playroom) dvLutron = 5001:4:0 // Lutron Homeworks - *See Main vdvLutron = 33021:1:0 // Virtual dev DEFINE_CONSTANT INTEGER KP_COUNT = 10 ; //Number of Phantom Keypads to track DEFINE_TYPE //Structure to Hold LEd Fedback STRUCTURE _sLighstLED { CHAR sLED_4_1[1] CHAR sLED_8_5[1] CHAR sLED_12_9[1] CHAR sLED_16_13[1] INTEGER nLED_1_4[4] INTEGER nLED_5_8[4] INTEGER nLED_9_12[4] INTEGER nLED_13_16[4] } DEFINE_VARIABLE //Current room the touch panel has selected volatile integer lightsCurRoom[TP_COUNT] DEV vTP_Lutron[] = {dvTP_Lutron1,dvTP_Lutron2,dvTP_Lutron3} _sLighstLED uLightsKpLED[KP_COUNT] VOLATILE INTEGER nLEDs_G1[4] VOLATILE INTEGER nLEDs_G2[4] VOLATILE INTEGER nLEDs_G3[4] VOLATILE INTEGER nLEDs_G4[4] //This function coverts the HEX values reported from the Lights LED to bit symbols // and then to manageable values. DEFINE_FUNCTION Process_LED_HEX(CHAR sHEX[1], INTEGER nLEDS[4]) { SWITCH(sHEX) { CASE '0': //0000 { nLEDS[4] = 0 nLEDS[3] = 0 nLEDS[2] = 0 nLEDS[1] = 0 } CASE '1': //0001 { nLEDS[4] = 0 nLEDS[3] = 0 nLEDS[2] = 0 nLEDS[1] = 1 } CASE '2': //0010 { nLEDS[4] = 0 nLEDS[3] = 0 nLEDS[2] = 1 nLEDS[1] = 0 } CASE '3': //0011 { nLEDS[4] = 0 nLEDS[3] = 0 nLEDS[2] = 1 nLEDS[1] = 1 } CASE '4': //0100 { nLEDS[4] = 0 nLEDS[3] = 1 nLEDS[2] = 0 nLEDS[1] = 0 } CASE '5': //0101 { nLEDS[4] = 0 nLEDS[3] = 1 nLEDS[2] = 0 nLEDS[1] = 1 } CASE '6': //0110 { nLEDS[4] = 0 nLEDS[3] = 1 nLEDS[2] = 1 nLEDS[1] = 0 } CASE '7': //0111 { nLEDS[4] = 0 nLEDS[3] = 1 nLEDS[2] = 1 nLEDS[1] = 1 } CASE '8': //1000 { nLEDS[4] = 1 nLEDS[3] = 0 nLEDS[2] = 0 nLEDS[1] = 0 } CASE '9': //1001 { nLEDS[4] = 1 nLEDS[3] = 0 nLEDS[2] = 0 nLEDS[1] = 1 } CASE 'A': //1010 { nLEDS[4] = 1 nLEDS[3] = 0 nLEDS[2] = 1 nLEDS[1] = 0 } CASE 'B': //1011 { nLEDS[4] = 1 nLEDS[3] = 0 nLEDS[2] = 1 nLEDS[1] = 1 } CASE 'C': //1100 { nLEDS[4] = 1 nLEDS[3] = 1 nLEDS[2] = 0 nLEDS[1] = 0 } CASE 'D': //1101 { nLEDS[4] = 1 nLEDS[3] = 1 nLEDS[2] = 0 nLEDS[1] = 1 } CASE 'E': //1110 { nLEDS[4] = 1 nLEDS[3] = 1 nLEDS[2] = 1 nLEDS[1] = 0 } CASE 'F': //1111 { nLEDS[4] = 1 nLEDS[3] = 1 nLEDS[2] = 1 nLEDS[1] = 1 } } } DEFINE_EVENT DATA_EVENT[vdvLutron] { STRING: { IF (FIND_STRING(DATA.TEXT, "'L1'",1)) IF(FIND_STRING(DATA.TEXT, "$0D,$0A",1)) { stack_var Integer nKeypad stack_var i // LED feedback //'L1010200',$0D,$0A //Capture Strings and Hex Values for LED positions REMOVE_STRING(DATA.TEXT, 'L1', 1) nKeypad = (ATOI(LEFT_STRING(DATA.TEXT,2))) uLightsKpLED[nKeypad].sLED_16_13 = (MID_STRING(DATA.TEXT,3,1)) uLightsKpLED[nKeypad].sLED_12_9 = (MID_STRING(DATA.TEXT,4,1)) uLightsKpLED[nKeypad].sLED_8_5 = (MID_STRING(DATA.TEXT,5,1)) uLightsKpLED[nKeypad].sLED_4_1 = (MID_STRING(DATA.TEXT,6,1)) Process_LED_HEX((uLightsKpLED[nKeypad].sLED_4_1),nLEDs_G1) Process_LED_HEX((uLightsKpLED[nKeypad].sLED_8_5),nLEDs_G2) Process_LED_HEX((uLightsKpLED[nKeypad].sLED_12_9), nLEDs_G3) Process_LED_HEX((uLightsKpLED[nKeypad].sLED_16_13), nLEDs_G4) //Update Structure with feedback values FOR (i = 1; i <= 4; i++) { uLightsKpLED[nKeypad].nLED_1_4[i] = nLEDs_G1[i] uLightsKpLED[nKeypad].nLED_5_8[i] = nLEDs_G2[i] uLightsKpLED[nKeypad].nLED_9_12[i] = nLEDs_G3[i] uLightsKpLED[nKeypad].nLED_13_16[i] = nLEDs_G4[i] } } } }
