Extron Switcher Power
Does anyone having Power ON/OFF commands for Extron Switcher?
  • mpullinmpullin Posts: 949
    If it follows SIS, > is supposed to turn it on and < will turn it off. I usually leave switchers on all the time so I am not positive about that second one.
    Agreed n the "leave it on" part. There's usually a lot if stuff down wire that won't like it going away. Usually the time I need to power a switcher down is a bad time and I'm cutting it off via a power controller.
    I leave switchers on too, but if they have power commands, I like to send an ON anyway, in case they got shut off for some reason I didn't anticipate. Which Extron switcher is it? I haven't used them in years, and the ones I have docs on don't have power commands.
  • MorgoZMorgoZ Posts: 116
    You have the technical manuals at the Extron webpage.
    If you can´t access them, tell us the switchwer model and maybe i could find you the command.
