bad situation working with level_event and bargraph, when panel go offline
i use a level_event to control lights, but i have a bad situation working with level_event and bargraph, when panel go offline the level goes to 0 and the the lights turn off, any idea to resolve this?
this is my code:
DEFINE_CALL 'F_LUZ_SALAJUNTAS_PLAFON' (INTEGER nPOTENCIA)
SEND_COMMAND dvRADIA_89,"'P1L',ITOA(nPOTENCIA),'T4'"
nLUZ_SALAJUNTAS_PLAFON = nPOTENCIA
BUTTON_EVENT[PANELS_ILUMINACION,101]
IF (!nLUZ_SALAJUNTAS_PLAFON)
CALL 'F_LUZ_SALAJUNTAS_PLAFON'(nLNOR) //ENCIENDE LA LUZ
ELSE
CALL 'F_LUZ_SALAJUNTAS_PLAFON'(nLAPA) //APAGA LA LUZ
SEND_LEVEL PANELS_ILUMINACION,1,nLUZ_SALAJUNTAS_PLAFON
LEVEL_EVENT[PANELS_ILUMINACION,1]
CALL 'F_LUZ_SALAJUNTAS_PLAFON' (LEVEL.VALUE) // LEE EL NIVEL DEL TP Y LO ASIGNA A LA LUZ
/* grettings & good codes */
this is my code:
ELSE
LEVEL_EVENT[PANELS_ILUMINACION,1] { if(isOnline(get_last(PANELS_ILUMINACION))) CALL 'F_LUZ_SALAJUNTAS_PLAFON' (LEVEL.VALUE) // LEE EL NIVEL DEL TP Y LO ASIGNA A LA LUZ }I typically use a channel on the bargraph as well as a level (or on the up/down ramping buttons if the bargraph is display only). I define a button event for this channel, and have it set a variable to TRUE in the push handler, and false in the release handler. Then test for the variable in the level event. This way level events only get processed when someone is touching the button causing a change, rather than any level change.
Hope this helps,
Don
http://www.amxforums.com/showthread.php?9896-Trouble-with-AMX-Multiroom-DAS-T-0808-SIG&p=67896#post67896
When the panel comes online, presumably you update the level with its current value so its in sync.
One method is to make the fader a button as well. So, when you touch the fader to move the volume you can withhold send_level until you let go.
Method two is as suggested above: abandon using the fader to adjust the level and use it strictly for display. Then use buttons to ramp the level up or down.
The third is stack two faders on top of each other. The bottom fader is display only. The top fader is transparent but is active. So your top fader adjusts the volume but the bottom one displays the level. You burn twice as many faders this way but it works.
if(device_id(level.input.device)) { // Do Your Light Stuff Here }
