Text Command don't display French ASCII character
Hi All,
i got a MXT-1001 and i'm trying to display text by using ^TXT Command
if i send to my panel
SEND_COMMAND dvtp,"'^txt-1,0,Français'"
it display Fran?ais
if i enter the text in the TP5 it works. any character higher than 127 doing this.
i have not tested it with another panel, i will try tonight but someone could point me in the correct direction.
thanks all.
    The ^TXT command only sends non-unicode text. You would need the ^UNI command to send unicode.
  • RaphayoRaphayo Posts: 111
    I will try that tomorrow.
    I just have to replace ^txt by ^uni ?
    Raphayo wrote: »
    Its not quite that simple. The text is sent as ASCII-HEX nibbles. Look up WC_ENCODE and WC_DECODE for built in functions that encode/decode unicode.
    "'^UNI-<variable text address range>,<button states range>,<unicode text>'"
    Set Unicode text. For the ^UNI command (%UN and ^BMF command), the Unicode
    Syntax:
    SEND_COMMAND <DEV>,"'^UNI-<vt addr range>,<button states range>,<unicode text>'"
    Variables:
    variable text address range = 1 - 4000.
    button states range = 1 - 256 for multi-state buttons
    (0 = All states, for General buttons 1 = Off state and 2 = On state).
    unicode text = Unicode HEX value.
    Example:
    SEND_COMMAND Panel,"'^UNI-500,1,0041'"
    Sets the button's unicode character to 'A'.
    Note: To send the variable text 'A' in Unicode to all states of the variable text
    button 1, (for which the character code is 0041 Hex), send the following command:
    SEND_COMMAND TP,"'^UNI-1,0,0041'"
    Note: Unicode is always represented in a HEX value. TPD4 generates
    (through the Text Enter Box dialog), unicode HEX values.
    It cannot be sample always something to give us a programming challenge..
