Samsung TV RS-232
Greetings,
Most of the modern Samsung TVs claim to have RS-232 control available through the 3.5 mm jack. I cannot find any documentation on it anywhere though.
Does anyone have any knowledge of serial control of Samsung TVs?
Thanks.
  • mpullinmpullin Posts: 949
    Here are commands that I sent to a ME32B that worked:
    DEFINE_FUNCTION tvCommand(INTEGER nCOMMAND){
        SWITCH(nCOMMAND){
    	case TV_POWER_OFF:
    	    SEND_STRING dvTV, "$AA,$11,$FE,$01,$00,$10"; // power off
    	break;
    	case TV_POWER_ON:
    	    SEND_STRING dvTV, "$AA,$11,$FE,$01,$01,$11"; // power on
    	    WAIT 60 tvCommand(TV_INPUT);
    	break;
    	case TV_INPUT:
    	    SEND_STRING dvTV, "$AA,$14,$FE,$01,$21,$34"; // hdmi
    	    WAIT 20{
    		tvCommand(TV_VOLUME);
    	break;
    	case TV_VOLUME:
    	    SEND_STRING dvTV, "$AA,$12,$FE,$01,$37,$48"; // volume = 55
    	    //SEND_STRING dvTV, "$AA,$12,$FE,$01,$4B,$5C"; // volume = 75
    	break;
    Baud is just the standard 9600 N 8 1.
    I will give that a try. I am asking about the consumer TVs though. I would suspect that they may be different than the commercial model documentation you posted.
    Thanks.
  • vincenvincen Posts: 526
    It works on consumer TV*but you are never able to get it on as it switches off the rs-232 port when it's in standby :(
  • nickmnickm Posts: 152
    vincen wrote: »
    Turn off all 'eco' settings and it will no longer kill the serial board when in standby. They do this out of the box to achieve EnergyStar ratings.
