Channel Vision Camera and Dynamic Image
RicardoSiqueira
I need to show the image of a network Channel Vision Camera on 4 iPads with TPControl. I've used Axis cameras for years and they work quite nice, as well as their Axis Severs. But I have to work with the existing Channel Vision Camera (Model 6522). Does anybody know the settings for the AMX TP4 Dynamic Images for the Channel Vision network cameras?
Thanks!
Ricardo
Thanks!
Ricardo
Ricardo,
Any luck with the answer. Trying to setup a Channel Vision 6524 now. Using TP4 to test but not much luck.
David
Ricardo,
I finally got the Channel Vision to work.
I have the 6521 1.3 MP Wall Camera and did a firmware update just to be sure.
I set mine up on port 8001.
In TP4 Dynamic Image:
Protocol:HTTP
Host xxx.xxx.xxx.xxx:8001 (Port)
Path: leave blank
File: GetData.cgi?CH=2
User: Default is admin
Password: Default is admin
Refresh 1
I used Stream 2 at 600x480 with an FPS of 5.
It serves up slowly so be patient.
FYI there might be some firmware issues with certain panel types that require a Tech Support Hot Fix. My 5200, 8400 and NXD500i all seem OK.
Let me know how it goes.
David
