Module Netlinx ?
HARMAN_Lanussinio
Hi,
I'm trying to doi a module SNAPI compliant in Netlinx and I want it toworks like a JAR module, but I'm facing issue for the VOL_UP and VOL_DN command.
With th JAR module I'm using a min_to for volume ramping and for the others commands a pulse.
In my netlinx module for the pulse I manage it with a channel event in the comm module but I don't find a way to manage the min_to ?
Any idea ?
Any idea ?
button_event[dvTP,0]
push:
switch(button.input.channel)
case 1: pulse[vdvDevice,PWR_ON]
case 2: pulse[vdvDevice,PWR_OFF]
case 3: min_to[vdvDevice,VOL_UP]
case 4: min_to[vdvDevice,VOL_DN]
case 5: pulse[vdvDevice,VOL_MUTE]
// From the comm Module
channel_event[vdvDevice,0]
on:
local_var integer nChannel
nChannel = channel.channel
switch(nChannel)
case PWR_ON: fnSendCommandToDevice ("cZone,cChannelOn,cETX")
case PWR_OFF: fnSendCommandToDevice ("cZone,cChannelOff,cETX")
case VOL_UP: fnSendCommandToDevice ("cZone,cVolumeUp,cETX")
case VOL_DN: fnSendCommandToDevice ("cZone,cVolumeDn,cETX")
case VOL_MUTE: fnSendCommandToDevice ("cZone,cVolumeMuteToggle,cETX")
The command is only sent one time but I want it to repeat as long the min_to ?
HOLD [2,REPEAT]:
case 1: // do your thing
case 2:
case 3:
case 4:
case 5:
Double click or highlight the keyword Min_to and hit F1. This will bring up the help file for the command. That should give you all the answers you need.
But min_to will not do anything differently than a pulse with the code you show.. In both cases the send string will only fire once.
So, how this works is the statement in define_program is constantly looking for the flag to go positive. when you hit the channel the flag goes positive and the wait 3 loop begins to run over and over sending the string until you let go of the channel thus making the variable go to zero. then the last wait will go through and stop.
this would mimic the behavior of a DUET module as you wish.
A pulse is going to turn the channel on for the default hold time (usually 5/10ths of a second) and then off.
A TO command will turn the channel on when you hit the TP button and then off when you release the TP button (however long you hold it)
A MIN_TO operates like a TO with the exception that also include a parameter of maximum time. So if the person does not release the button within the allotted time, the program does it for them.
A TO or MIN_TO does not cause the channel to repeat it's action over and over again until you let go. It still only fires one 'ON' and one 'OFF'
Well, yes there are quire a few ways to pull this off. I would probably use a timeline myself. The principle is still the same either way.
Truth is, if a Duet module is connected to device that only has discreet serial commands for volume ramping, then internally it is doing the exact same thing you have to do here - it just hides it in a black box.
