Kindergarten level programming
Hi,
Anyone willing to help?
I'm trying to make an AMX TP button ramp an amp channel up whilst it's pressed.
If I send the string once, it increments the volume 1db at a time. So I've tried to create a TO Command to repeat the sending.
DEFINE_CALL 'Surround Amp Up'
IF(SURROUND_AMP_UP)
WAIT 2
SEND_STRING dvSURROUND, "$50, $43, $53, $45, $4E, $44, $02, $04, $80, $70, $C7, $38, $47, $48"
BUTTON_EVENT[dvTP1,11]
TO[dvTP1,11]
TO[SURROUND_AMP_UP]}
I'm a novice, playing at home, so be nice please :)
  • This code has not been tested, but in general this is what I do with Volume Ramping.
    Integer dvTP1_ButtonHold;
    Define_Function SurroundAmpUp(Dev Device)
    	//Should be putting this into a Queue and firing out in a Timeline
    	//@ a predetermined interval
    	SEND_STRING Device, "$50, $43, $53, $45, $4E, $44, $02, $04, $80, $70, $C7, $38, $47, $48";
    BUTTON_EVENT[dvTP1, 11]
    		dvTP1_ButtonHold = False;
    	RELEASE:
    		if ( !dvTP1_ButtonHold )
    			TO[Button.Input];
    			SurroundAmpUp(dvSURROUND);
    	HOLD[2, REPEAT]:
    		dvTP1_ButtonHold = True;
    		TO[Button.Input];
    Another method
    When needing to ramp volume like this I use timelines.
    LONG lVolumeDelay[]={150}
    INTERGER nVolRamping
    BUTTON_EVENT[vdvTP_Vol,nVolBtn]
              IF(!nVolRamping)
                   nVolRamping=1
                   // send the ramp volume command
                   TIMELINE_CREATE(tlVolRamp,lVolumeDelay,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT)
         RELEASE:
              nVolRamping=0
              TIMELINE_KILL(tlVolRamp)
    TIMELINE_EVENT[tlVolRamp]
  • the8thstthe8thst Posts: 470
    TonyAngelo wrote: »
    INTERGER nVolRampingTimeOut = 30
              IF(!timeline_active(tlVolRamp))
         RELEASE:
        if (timeline.repetition < nVolRampingTimeOut)
        else
               timeline_kill(tlVolRamp)
    I made couple small changes. I got rid of the integer variable because it is redundant, and I added a guard against runaway volume if a button release is missed (habit from R4 days).
    Not saying it's wring, because it's a perfectly valid approach, but I've personally always felt timelines were overkill. I use the HOLD [REPEAT, n] method. You can adjust the repeat value if the serial port overruns or keeps going too long; if you buffer your commands, you can also clear the queue on a RELEASE. My problem with serial devices has always been, however, that unless there is a built-in ramp command, it's really fussy to get the ramping to go smoothly without overruns.
  • huttencmhuttencm Posts: 23
    I am with Dave, try this
    BUTTON_EVENT [dvKP,9] // SELECT Volume Up KEYPAD BUTTON (#9)
    HOLD[2,REPEAT]:
    IF (nVol_Lvl < 100)
    PUT YOUR STRING HERE
    nVol_Lvl = nVol_Lvl + 1
    ON [dvKP,9]
    RELEASE:
    OFF [dvKP,9]
