volume up/down
kfahmy
i have have to control a LED TV volume up/down using the code below
BUTTON_EVENT [ dvTP_CD,BUTTON.INPUT.CHANNEL]
PULSE[dv_CD,BUTTON.INPUT.CHANNEL]
but the increase in volume increased step by step as i press on button, i want to increase the volume as long as the button is pressed
any idea????
any idea????
From the help file:
A HOLD event handler specifies the actions that should be performed when a button is pressed and held for a minimum length of time indicated by the TIME parameter (specified in 0.1 second increments).
The REPEAT keyword is used to specify that the event notification should be repeated in TIME increments as long as the button is held.
Example:
BUTTON_EVENT[DEVICE,CHANNEL]
// PUSH event handler
RELEASE:
// RELEASE event handler
HOLD[TIME]: or HOLD[TIME, REPEAT]:
// HOLD event handler
