Hotel door lock ?
Hello,
We are searching for a solution of door lock for an hotel, connected to the PMS.
The room will be control by AMX but the owner would like to have some light turn at 100% during the cleaning session and the shade to be open.
Does any of you know a solution ?
Thanks for your help.
    CedricCedric Posts: 32
    Just in case someone searching, most of them are now using ZigBee but some would be using rs485
    viningvining Posts: 4,368
    You could lok into Keri Systems card/keyfob readers to trigger AMX -> lighting system.
    Lot of KNX hardware out there too - just not that common in North America.
    The solution might be going on a ZigBee solution with some gateway
    You could also try
    SAFLOK (They integrate with Control4 so should be able to integrate with AMX)
