Very Long Delay using iPad TPC Control
danlee20
Here is the issue:
We are using 4 ipad Airs with the AMX TPC control app. The delay is between 7-10 seconds from when a button is pressed and the action is done. My initial thoughts are this is related to a network setup? We are using a decent Netgear router with static IP's. We have an AMX touch panel installed and hardwired in the rack on the same router, that works perfect. Any thoughts or suggestions on what to try would be greatly appreciated. Thank you
ooff. Sussing out network troubles can be a bear. I would recommend very careful systematic troubleshooting.
First thing is to determine the nature of the wireless connection to the iPad. Is it slow for other network related issues? You could also get any number of apps that will allow you to ping from the iPad to the Nettlinx controller and figure out just what's going on. Do not forget to look at the analog side of digital wifi. Are there other WAPs interfering with the one you're connected to? Are there any WAPs within range on the same channel? If so , that could certainly slow things down quiet a bit while still looking like connections are normal. Hopefully, you are not using wireless repeaters or extenders.
if the WiFi looks good then check the switch. Do you have any loops by accident. (Port of a switch plugged right back into a port on the switch) I've seen this a lot when you find networks with sub-switches located elsewhere on the property. they inadvertently create a loop by plugging in a feed from the main switch into a port on the remote switch and then running another feed to another port on the sub.
If everything checks out there I'd get wire shark involved.
I have seen some pokiness on some TPControl apps but nothing even close to that.
but one question the wifi router is inside the rack ? if so make some test with it outside.
1. Does the ipad button "react" to being touched immediately, or is the "beep" feedback delayed for the duration, then when it is seen/heard, the command goes through? If so, the problem is at the panel and IS NOT a WIFI issue. Until the button reacts, it has nothing to say to the NetLinx.
2. Look at events in NetLinx Studio. When do you see the push arrive? Does the delay occur before you see it in STUDIO, or after. If AFTER, it is a processing delay in your program.
These are not cures, but it's nice to eliminate major suspects before deeper troubleshooting.
I have used TPControl on iPads on several projects in the past and have noticed a little lagginess, but nothing that interferes with operations.
However, I am currently on a new installation that was showing the exact same symptoms that are described in this thread. Through troubleshooting I was able to rule out networking or WiFi issues as potential causes, so I was at a loss.
Fortunately I noticed that an update was issued in the App Store a few days ago. This seems to have resolved the extreme lagginess for me and replaced it with the normal lagginess. Actually, it even seems a little snappier than I remember it.
I hope this helps.
