LUTRON RadioRa2 Keypad event
Cedric
Hi,
I'm working on a new project with a RadioRa2 and a Keypad.
But I can't find how to receive the event from the Keypad.
I can set the light level, so the com between the master and RadioRa2 is working.
So the Chanel_event is not working, can anyone help me with this part?
Thanks for your help.
DEFINE_DEVICE vdvLutronRadioRA2 = 41001:1:0 dvLutronRadioRA2 = 0:3:0 DEFINE_CONSTANT VOLATILE CHAR sKeypadAddress[20][20] = { '6:B1', //Keypad1 Button 1 '6:B2', //Keypad1 Button 2 '6:B3', //Keypad1 Button 3 '6:B4', //Keypad1 Button 4 '6:B5', //Keypad1 Button 5 '6:B6' //Keypad1 Button 6 } VOLATILE CHAR sLightAddress[20][20] = { '7:D1', // Dimmer 1 '8:D1', // Dimmer 2 '9:D1' // Light Test } DEFINE_VARIABLE DEV vdvDev[] = {vdvLutronRadioRA2} INTEGER nLutronRadioRA2 = 1 INTEGER nLutronRadioRA2Pages[] = { 1 } INTEGER nKeypadSystemPages[] = { 2 } INTEGER nModulePages[] = { 3 } DEFINE_START DEFINE_MODULE 'Lutron_RadioRA2_Comm_dr1_0_0' comm(vdvLutronRadioRA2, dvLutronRadioRA2) DEFINE_EVENT DATA_EVENT[vdvLutronRadioRA2] { ONLINE: { WAIT 50 { SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-IP_Address,192.168.33.101'" SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-Login,lutron'" // lutron SEND_COMMAND vdvLutronRadioRA2,"'PROPERTY-Password,integration'" //integration SEND_COMMAND vdvLutronRadioRA2,"'REINIT'" } } } CHANNEL_EVENT[vdvLutronRadioRA2,0] { ON: { send_command vdvLutronRadioRA2, "'LIGHTSYSTEMLEVEL-9:D1,100,2'" } }
You have to use the event string in your data_event of your virtual device to have the feedback of your keypad.
You can use the command ?KEYPADSYSTEMBUTTONSTATUS-<address> to get the status of the specified button.
example:
send_command vdvLutronRadioRA2,"'?KEYPADSYSTEMBUTTONSTATUS-7:B1''"
So I have to add:
But where should I put the send_command vdvLutronRadioRA2,"'?KEYPADSYSTEMBUTTONSTATUS-7:B1''" ?
String :
And nothing is happening
Do you have message in your notification bar regarding the lutron virtual device ?
You should see someting when you click on your lutron keypad
Line 1 (17:53:36):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B1,PUSH]
Line 2 (17:53:36):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B1,RELEASE]
Line 3 (17:53:43):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B2,PUSH]
Line 4 (17:53:43):: Command From [41001:1:1]-[KEYPADSYSTEMBUTTONSTATE-6:B2,RELEASE]
So I might use the ''COMMAND :''
Withe FIND_STRING(DATA.TEXT,
If someone had the same problem
here is the code :
Why are you doing the remove string? string manipulation is a pretty spendy process. why bother if you're not doing anything with it?
I was thincking of remooving and just keeping the id for switch/case but not sur if I really need it also.
You might want to make your code more generic. I split the feedback into multiple parts so I have a variable for the command (KEYPADSYSTEMBUTTONSTATE), for the ID (6), for the type(B) and the button number (1), and the event (PUSH). I don't always need this level of granularity, but when you have a large house with a mixture of keypads, dimmers, shades, sensors, etc, you can more easily identify what's going on.
