8400i Intercom setup
I have a 8400i and want to utilize the intercom capability. By reviewing the 8400i installation guide it states:
Panel Intercom Configuration
Incorporating An Intercom Capable Panel Into Your NetLinx System
Download the module for the intercom panel from www.amx.com, and include it in your
NetLinx project file.
well I assume this means AMXCommunications.zip which when unzipped produces AMX Communications_2_30.AXW file which is a project module for the intercom. So question I have is:
1) do I incorporate the AMX Communications_2_30.AXW module into my existing project as a module?
2) do I also incorporate the TP4 file intercom pages AMX_CSGComm_8400i with my existing TP4 file?
3) how does all this tie together?
But, a couple things to know. Oddly enough the commands being sent out by the comm module look suspiciously familiar when you look at them in diagnostics. In fact they are pretty much the same as what you send to the module itself to initiate calls and so forth.
I ended up just sending the commands straight to he TP. The commands are in the programming manual if the 8400i.
And now the other issue to consider... The intercom functionality on the 8400 was poor at best. (IMHO). Every time I tried to implement it the results were so poor I just turned it off. Problems with the SIP connection, problems with the audio quality, problems dropping calls, etc...
If I were you I wouldn't imliment the feature.
I want to use the 8400i to communicate between panels - one 8400i to another 8400i. So I don't want to make phone calls just use intercom feature. So I want to be able to setup my 8400i panels to just get the intercom feature to work and am a little confused on how to do so.
Is this the word doc that has the protocol ur referring to -- AMX Voice & Video Communications Module Interface.doc?
The intercom uses the SIP function. The trouble is the intercom function. It doesn't work very well. I'd not implement it.
We found that the module design that seeks out all the intercom panels dynamically and sets up the list is the major problem. It is so busy and invasive that panels go offline during discovery, triggering a new round of discovery. Lather, rinse, repeat. Never get done.
We implemented fixed IP's and intercom items identified already in data (you could hard code in code...) for the intercom panels, and forgo all the automatic bits. Works well. Much faster.
That's not true. I use the intercom module without SIP as it uses VOIP. You can download the module that uses SIP in conjunction with the telephony server, or just use the intercom module on its own. I use the intercom on iPads which don't support SIP, and I have a couple projects that have a telephony server and SIP panels and iPads. The panels that support SIP use the SIP protocol, and the iPads use VOIP. The only drawback is that the ECOMMs use one or the other, so either the SIP panels get audio to the ECOMMs, or the iPads do, but not both, so I typically leave the iPads out of the doorbell feature.
I think the intercom feature actually works quite well most of the time if the network is robust. But the module seems like it was written hastily and has some issues you might want to correct.
I have 2 -- 8400i and want to utilize the intercom capability so the panels can communicate with one another.
I don't want to use the AMX module I just want to code it by hand - so I need to know the protocol or commands to initiate communication.
Does anyone know the commands? I think the commands are ^ICE, ^ICM, ^ICS -- but am not sure
They are all in the AMX-PI.
Ok by looking up codes in PI, if I issue these two simple commands to the touchpanels – should I get a baby monitor working when at one panel I can talk and the speaker from other panel will hear?
Is there any other commands that would be issued?
Example of setting up a baby monitor call where the first panel is listening to the microphone audio coming from the second panel:
send_command dTP_MAIN[11], "'^ICS-192.168.1.141,9000,9002,0'";
send_command dTP_MAIN[12], "'^ICS-192.168.1.143,9002,9000,1'";
So many more things are required to turn this into a solution, not just a connection. To use a automobile analogy, How do you get from San Francisco to Phoenix? Simple, the controls are left, right, stop, and start. You're all set.
I just want to get one panel to talk to the other panel - lets say I have 2 panels in my whole system and both are 8400i.
I want to to speak into one panel and hear the voice in the other panel. If I can get that to work then I can worry about the things you mentioned. Just a basic test to see if this works
Should this code do what I want?
^ICM-TALK to the sender and ^ICM-LISTEN to the receiver.
I tried those commands also - to no avail. I am thinking maybe my 2- 8400i touch panels may have the intercom support disabled. Is there a way to check this? If it is disabled how do they get enabled?
here is what I tried:
Also, I tried ^ICM-TALK to the sender and ^ICM-LISTEN to the receiver - also to no avail - all the commands listed in the PI I tried.
The only way I know my 2 panels are 8400i's is the Device ID -289 they are associated whereas a normal 8400 panel has device ID of 323.
So I assumed that these panels are 8400i's but have not got any indication that the intercom works on these panels.
Under audio settings in Setup page I do see Intercom Mic level and Volume.
I did find this in another post:
If you issue a command that checks to see if the panel is capable of intercom :
: Send_command dtp_MAIN , “^MODEL?”
After this command is issued ---- If the panel supports intercom hardware it will respond with its model name as shown in the response below.
^MODEL-MVP-8400i
Does this response come into the Data_Event of dtp_MAIN ??
DATA_EVENT[dTP_MAIN]
STRING:
-response here
I don’t get a response from that command
Posting the same questions in multiple different threads can be wasteful of time and resources. It also increases your chance of missing the right answer.
your right I didnt see you post from the other Thread, but I saw something in that thread and should have copied and pasted back to this thread, instead of Replying
