Raise Custom Event - Error 0xF075
Hello
(Sorry my English is a little bad)
I am a beginner in NetLinx and found in the File NetLinx.axi the method:
DEFINE_LIBRARY_FUNCTION DO_CUSTOM_EVENT(CONSTANT DEV A, CONSTANT TCUSTOM
But how i can use this function? The function is not documented.
I try follow coding:
Now I execute the code and receive the following error: CIpLibrary::CallFunction - Error 0xF075
Why that or what can I do?
DEFINE_DEVICE dvSystem = 00000:001:000 // Master NI 700 dvPanel = 10001:001:000 // Touchpanel DEFINE_VARIABLE TCustom CustEvent DEFINE_EVENT data_event[dvPanel] { online: { send_string 0,"'Touchpanel online ...'" // It works send_command dvPanel, "'?TXT-1,0'" send_string 0, ("'Prepare do_custom_event ...'") CustEvent.Device = dvPanel CustEvent.ID = 1 // Address CustEvent.Type = 1001 // EventId CustEvent.Flag = 0 // 0 means text is a standard string, 1 means Unicode encoded string CustEvent.Text = 'Test' CustEvent.Value1 = 1 CustEvent.Value2 = 4 CustEvent.Value3 = 1 // cust.SourceDev = dvSystem send_string 0, ("'Start of Execute do_custom_event ...'") // CIpLibrary::CallFunction - Error 0xF075 do_custom_event(dvSystem, CustEvent) // or dvPanel send_string 0, ("'End of Execute do_custom_event ...'") } } custom_event[dvPanel, 1, 1001] { Send_String 0,"'ButtonGet Id=',ITOA(CUSTOM.ID),' Type=',ITOA(CUSTOM.TYPE)" Send_String 0,"'Flag =',ITOA(CUSTOM.FLAG)" Send_String 0,"'VALUE1 =',ITOA(CUSTOM.VALUE1)" Send_String 0,"'VALUE2 =',ITOA(CUSTOM.VALUE2)" Send_String 0,"'VALUE3 =',ITOA(CUSTOM.VALUE3)" Send_String 0,"'TEXT =',CUSTOM.TEXT" Send_String 0,"'TEXT LENGTH =',ITOA(LENGTH_STRING(CUSTOM.TEXT))" send_string 0,"'Device = ', DevToStr(Custom.Device)" send_string 0,"'SourceDev = ', DevToStr(Custom.SourceDev)" }
And you also have the send command which works: but then populate a structure and call that function which I assume is doing the same as the send command above except ones going to the system and the other to the panel. If the send command works and you get a print out in diagnostics from your custom event handler's send_string 0's the error is likely because the function call is sending to dvSystem not dvPanel.
