Big string to widechar string - error
karageur
Hi everyone!
I can’t convert big string buffer to widechar string.
The incoming string buffer is (sHTTPBuffer length = 39708) rather big and if I do this
wcHTTPBuffer = WC_DECODE(sHTTPBuffer, WC_FORMAT_UTF8, 1)
OR
wcHTTPBuffer = ch_to_wc(sHTTPBuffer)
and I get loop of this errors in diag
Line 11 (12:51:32):: Ref Error ? Index to large Line=3649
Line 12 (12:51:32):: SetVariable - Error 1 Tk=0x0000
I tried to change the array size
volatile widechar wcHTTPBuffer [50000] or
volatile widechar wcHTTPBuffer [100000] or
volatile widechar wcHTTPBuffer [1000000]
But if incoming’s char buffer length is (sHTTPBuffer length = 4262) – no errors and widechar is converted correctly.
Please advise.
OR
Please advise.
I think you're right.
I also tried
sTempBuffer = "sTempBuffer, data.text" in string event, but sTempBuffer stays always 15999 length though it's global var.
I should try char by char copy ...
If anyone has such examples I would be very thankfull.
you might try using CREATE_BUFFER. Its size limit is much bigger.
CREATE_BUFFER dvIP_TCP_Client_Http, sHTTPBuffer
and it grows to 65000 length.
But unfortunately I can't do this >>
This doesn't work either if sHTTPBuffer is more than 16000
for (i=1; i<=length_string(sHTTPBuffer); i=i+9999) {
wcTemp = ch_to_wc(mid_string(sHTTPBuffer,i,9999))
wcHTTPBuffer = wc_concat_string(wcHTTPBuffer, wcTemp)
is to make an array of widechar strings.
But extracting strings from an array and parsing on the fly can be a challange.
Do you use ASCII string or UTF string when parsing ?
The buffer I use is defined like this:
Volatile Char cDataBuffer[8192]
And that is probably twice as large as it would need to be.
I used the RFC as a protocol document for the internet when I wrote my module:
https://www.ietf.org/rfc/rfc2616.txt
I changed WC_MAX_STRING_SIZE in UnicodeLib.axi from 16 000 to 160 000 and functions
like WD_DECODE and CH_TO_WC started to work with large text buffer!
I'd be very careful tweaking under the hood like that. It could have unforeseen consequences that can bite you later.
