DAY_OF_WEEK (DATE)
hi
for tracking event's only on several day's, i take the following cmd: DAY_OF_WEEK (DATE) put it on a sinteger.
that works fine with a button_event or in the startup.
but i want refresh the variable every night on 12pm. so there is a channel_event every night on the same time. the channel_event works every night, but the following cmd doesn't seem to work in this channel_event:
nDay = DAY_OF_WEEK (DATE)
the variable doesn't change.
any hint's?
thanks
john
    Couple things. Maybe you just mistyped, but 12pm is noon, not midnight. In fact, there is a debate that AM and PM are meaningless at 12, and you should always call it noon or midnight ... but in your AMX master, 12 is noon, and 00 is midnight. Second, I'm pretty sure you want your channel to be at 00:01. I do not believe the new day starts until after 12, not exactly at 12. Third, double check the scope of your variable. If it's defined in the event, or if you simplified for the forums and there are other re-assignemts in there, make sure whatever variable you are sticking the result in has a scope outside the event. Once the event has passed, it's going to be meaningless if defined inside the event as stack.
  • GregGGregG Posts: 251
    I usually run a checking timeline every minute to update things that don't change very often. And instead of waiting for the channel event, you could just put the code you need to execute on certain days into the checking timeline itself:
    DEFINE_CONSTANT
    TL_CHECK_DOW_CHANGE = 2
    Volatile Long lTimes[1]
    Persistent Integer nDayOfWeek
    lTimes[1] = 60000 // Every 60 seconds
    Timeline_Create(TL_CHECK_DOW_CHANGE,lTimes,1,TIMELINE_RELATIVE,TIMELINE_REPEAT)
    Timeline_Event[TL_CHECK_DOW_CHANGE]
      // Use this "If" to determine the first time we find a new day
      If(nDayOfWeek <> DATE_TO_DAY(DATE))
          FunctionToPerformThingsOnCertainDays( DAY_OF_WEEK(DATE) )
      // Just use this to only update the day variable
      nDayOfWeek = DAY_OF_WEEK(DATE)
  • hi all
    thanks for the replies.
    first, sorry i mean midnight correct :-)
    my channel_event works on midnight every night. i do this with (COMPARE_STRING(TIME,'00:05:0?'))
    my problem is in the ON event of the channel_event the cmd:
    doesn't be updatet. all other cmd in this event works.
    example:
    CHANNEL_EVENT[vdv__EVENT,003]
    ON:
    nDAY = DAY_OF_WEEK (DATE)
    Have you tried putting a line like this in the channel event after your assignment to see what it tells you:
    ON:
    Send_String 0,"'nDAY=',Itoa(nDAY),' DAY_OF_WEEK(DATE)=',Itoa(DAY_OF_WEEK(DATE))"
    This could help you determine if something else in your code is making changes that you didn't expect.
    I use a date & time.axi that runs on a 250ms repeating timeline that always runs and so that everything is always available. There are some things declared in my constants.axi or in my main.axs but it's should be pretty apparent what the functions are for and you can comment out as you need and create your own code to utilize some of the calls.
    Here's the axi code, use all, part or none as you see fit.
    PROGRAM_NAME='VAV_Date_&_Time'
    DEFINE_CONSTANT //DST                           <<<*************************  CHANGE SETTING PER JOB *********************************>>>
    //Typically clocks are adjusted forward one hour near the start of spring and are adjusted backward in autumn.[1]
    //Starting in 2007, Daylight Saving Time (DTS) has been extended by one month. Therefore, the start date of DTS in the United States has been
    //changed to the 2nd Sunday in March and the end date of DTS has been changed to the 1st Sunday in November
    //If Daylight Savings Time is currently being observed (between spring and fall), set this item to "1". If Daylight Savings Time
    //is not currently being observed (between fall and spring) or is not observed in your geographic location, set this item to "0".
    //This item is used to correctly calculate the times for sunrise and sunset.
    INTEGER DST_OBSERVED		= 1;  		//1 for yes and 0 for no
    INTEGER DST_OFFSET		= 1;  		//number of hours time is offset
    INTEGER DST_BEGIN_MONTH		= 3;  		//March (months 1-12 January to December)
    INTEGER DST_END_MONTH		= 11; 		//November (months 1-12 January to December)
    INTEGER DST_BEGIN_DAY		= 1;  		//Sunday (day of week 1-7 Sunday to Saturday)
    INTEGER DST_END_DAY		= 1;  		//Sunday (day of week 1-7 Sunday to Saturday)
    INTEGER DST_BEGINDAY_OCCURANCE	= 2;  		//Number of occurances of that day in that month (2nd Sunday)
    INTEGER DST_ENDDAY_OCCURANCE	= 1;  		//Number of occurances of that day in that month (1st Sunday)
    CHAR DST_BEGIN_TIME[]		= '02:00:00';	//Time change occurs
    CHAR DST_END_TIME[]		= '02:00:00';	//Time change occurs
    DEFINE_CONSTANT //ASTRO_CLOCK LAT/LONG          <<<*************************  CHANGE SETTING PER JOB *********************************>>>
    INTEGER CLKMGR_DST		= 1;     	//1 for ON and 0 for OFF
    INTEGER CLKMGR_DST_OFFSET_HR	= 1;     	//1 for 1 hour
    INTEGER CLKMGR_DST_OFFSET_MIN	= 0;     	//0 for 0 minutes
    INTEGER CLKMGR_DST_OFFSET_SEC	= 0;     	//0 for 0 seconds
    INTEGER CLKMGR_RESYNC_PERIOD	= 240;     	//in minutes 480 = 8 hours, choices: 5 min, 15 min, 2 hour, 4 hours & (8 hours?)
    					        //the web interface doesn't show an 8 hour option but the keyword example only shows
    					        //an hour hour example. So I choose the highest the web gui lists 4 hours/240 minutes.
    DOUBLE CLKMGR_LAT		= -73.42;	//Longitude - Longitude in Degrees.Fraction of Degrees. West longitudes must be negative.
    DOUBLE CLKMGR_LONG		= 41.98; 	//Latitude - Latitude in Degrees.Fraction of Degrees. South latitudes must be negative
    DOUBLE CLKMGR_OFFSET_GMT_EST	= -5.0;  	//HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as
    DOUBLE CLKMGR_OFFSET_GMT_EDT	= -4.0;  	//HoursFromGMT - Number of hours from GMT. Hours West of GMT can be entered as
    CHAR CLKMGR_TIME_ZONE[]		= 'UTC-05:00';	//Input string must have the correct format: UTC[+|-]HH:MM
    CHAR CLKMGR_ACTIVESERVER[] 	= '132.163.4.101';
    DEFINE_CONSTANT //TIME CONSTANTS Days of Week & Month of Year
    SUNDAY        	= 1;
    MONDAY        	= 2;
    TUESDAY       	= 3;
    WEDNESDAY     	= 4;
    THURSDAY      	= 5;
    FRIDAY        	= 6;
    SATURDAY      	= 7;
    JANUARY		= 1;
    FEBRUARY	= 2;
    MARCH		= 3;
    APRIL		= 4;
    MAY		= 5;
    JUNE		= 6;
    JULY 		= 7;
    AUGUST		= 8;
    SEPTEMBER	= 9;
    OCTOBER		= 10;
    NOVEMBER	= 11;
    DECEMBER	= 12;
    FIRST           = 1;
    SECOND          = 2;
    THIRD           = 3;
    FOURTH          = 4;
    FIFTH           = 5;
    EXPIRES_IN_SECONDS      	= 10;
    INTEGER NUM_SECONDS_MINUTE	= 60;
    INTEGER NUM_SECONDS_30MIN	= 1800;
    INTEGER NUM_SECONDS_HOUR	= 3600;
    LONG NUM_SECONDS_DAY	    	= 86400;
    INTEGER NUM_MINUTES_HOUR	= 60;
    INTEGER NUM_MINUTES_DAY		= 1440;
    CHAR DAY_OF_WEEK_ABREV[7][3]   = {'SUN','MON','TUE','WED','THU','FRI','SAT'}
    CHAR DAY_OF_WEEK_FULL[7][9]    = {'Sunday','Monday','Tuesday','Wednesday','Thursday','Friday','Saturday'}
    CHAR MONTH_OF_YR_ABREV[12][3]   = {'Jan','Feb','Mar','Apr','May','Jun','Jul','Aug','Sep','Oct','Nov','Dec'};
    CHAR MONTH_OF_YR_FULL[12][9]    = {'January','February','March','April','May','June','July','August','September','October','November','December'};
    CHAR DAYS_MONTHs[12]        	= {31   ,28   ,31   ,30   ,31   ,30   ,31   ,31   ,30   ,31   ,30   ,31};
    CHAR DAYS_LEAPMONTHs[12]    	= {31   ,29   ,31   ,30   ,31   ,30   ,31   ,31   ,30   ,31   ,30   ,31};
    DEFINE_CONSTANT //UI FEEDBACK EVENTS
    FB_TIME_TIME       	= 1;
    FB_TIME_SUNRISE		= 2;
    FB_TIME_SUNSET		= 3;
    FB_TIME_DST		= 4;
    FB_TIME_HOLIDAY		= 5;
    DEFINE_TYPE     //TIME STUFF
    STRUCTURE _sMyTime
         INTEGER 	nYear;
         INTEGER 	nMonth;
         INTEGER 	n24Hour;
         INTEGER 	n12Hour;
         INTEGER 	nMinute;
         INTEGER 	nSecond;
         INTEGER 	nDayOfMonth;
         INTEGER 	nDayOfWeek;
         INTEGER  	nDayOccurance[7];
         LONG	nTime_Seconds;
         LONG	nTime_Minutes;
         CHAR	c24Time[8];
         CHAR	c12Time[8];
         INTEGER 	nWeekOfMonth;
         INTEGER 	nPlusDays;
         INTEGER 	nDaytime;
         INTEGER    nTimePM_flag;
         CHAR       cAMPM[2];
         LONG     	nSunriseTime;
         LONG     	nSunSetTime;
         CHAR 	cSunrise[10];
         CHAR 	cSunset[10];
         INTEGER 	nSunset24Hour;
         INTEGER 	nSunset12Hour;
         INTEGER 	nSunsetMinute;
         INTEGER 	nSunsetSecond;
         INTEGER 	nSunriseHour;
         INTEGER 	nSunriseMinute;
         INTEGER 	nSunriseSecond;
         CHAR     	cHoliday[24];
         CHAR     	cDay[3];
         CHAR     	cDate[8];
         CHAR 	cWebCurDateTime[29];
         CHAR 	cWebExpDateTime[29];
    DEFINE_TYPE     //DST
    STRUCTURE _sMyDST
         INTEGER nDST_Active;
         INTEGER nOffset;
         INTEGER nObserved;
         INTEGER nBEG_Month;
         INTEGER nEND_Month;
         INTEGER nBEG_Day;
         INTEGER nEND_Day;
         INTEGER nBEG_DAY_Occurance;
         INTEGER nEND_DAY_Occurance;
    DEFINE_TYPE 	//_sGet_ClkMgr
    STRUCTURE _sGet_ClkMgr
         INTEGER nReSyncPeriod;
         INTEGER nIs_DST_On;
         CHAR cTimeZone[9];
         CHAR cDST_StartRule[128];
         CHAR cDST_EndRule[128];
         CLKMGR_TIMESERVER_STRUCT sActiveTimeServer;
         CLKMGR_TIMEOFFSET_STRUCT sOffset;
         CLKMGR_TIMESERVER_STRUCT sTimeServers[4];
    DEFINE_TYPE     //CLKMGR_TIMEOFFSET_STRUCT FROM NETLINX.AXI FOR REFERNCE ONLY
    STRUCTURE CLKMGR_TIMEOFFSET_STRUCT
         INTEGER     HOURS;
         INTEGER     MINUTES;
         INTEGER     SECONDS;
    DEFINE_VARIABLE //STRUCTURES
    PERSISTENT _sMyTime sMyTime;
    VOLATILE   _sMyDST sMyDST;
    VOLATILE   _sGet_ClkMgr sGet_ClkMgr;//just holds the get queries
    VOLATILE INTEGER nTimeWait_Force = 1;
    VOLATILE INTEGER nTime_DeBug = 1;
    DEFINE_VARIABLE //TIMELINE
    VOLATILE LONG nTL_TIME_RT[] = {250};
    DEFINE_FUNCTION LONG fnConv_24HrTimeToSeconds(CHAR iTime[])
         RETURN ((((ATOI(REMOVE_STRING(iTime,"':'",1)) * 60) + ATOI(REMOVE_STRING(iTime,"':'",1))) * 60) + ATOI(iTime));
    DEFINE_FUNCTION CHAR[8] fnConv_SecondsTo24HrTime(LONG iTimeInSeconds)
         RETURN   "right_string("'0',ITOA(iTimeInSeconds / 3600)",2),':',
    		    right_string("'0',ITOA((iTimeInSeconds % 3600) / 60)",2),':',
    			 right_string("'0',ITOA((iTimeInSeconds % 3600) % 60)",2)";
    DEFINE_FUNCTION CHAR[30] fnDo_24hrTimeAddition(CHAR iLDate[],CHAR i24HourTime[],LONG iSecondsAdded)
         STACK_VAR INTEGER nYear;       //change to all stack_var's
         STACK_VAR INTEGER nMonth;
         STACK_VAR INTEGER nLeap;
         STACK_VAR CHAR c24HrTime[8];
         STACK_VAR CHAR cNewDate[10];
         STACK_VAR LONG nDay;
         STACK_VAR LONG nDaysOver;
         STACK_VAR LONG nSecondsRemain;
         STACK_VAR LONG nTotalTimeSeconds;
         nTotalTimeSeconds = fnConv_24HrTimeToSeconds(i24HourTime) + iSecondsAdded;
         nMonth = atoi("REMOVE_STRING(iLDATE,"'/'",1)");
         nDay   = atoi("REMOVE_STRING(iLDATE,"'/'",1)");
         nYear  = atoi("iLDATE");
         if(nTotalTimeSeconds > NUM_SECONDS_DAY)
    	  STACK_VAR INTEGER i;
    	  nDaysOver = nTotalTimeSeconds / NUM_SECONDS_DAY;
    	  nSecondsRemain = nTotalTimeSeconds % NUM_SECONDS_DAY;
    	  if(!(nYear % 4))//http://en.wikipedia.org/wiki/Leap_year
    	       nLeap = 1;
    	       if(!(nYear % 100))//double check these rules??????
    		    if(nYear % 400)
    			 nLeap = 0;
    	  if(nLeap)
    	       if((nDaysOver + nDay) > DAYS_LEAPMONTHs[nMonth])
    		    nDaysOver = nDaysOver - (DAYS_LEAPMONTHs[nMonth] - nDay);
    		    nMonth++;
    		    for(nMonth = nMonth; nDaysOver > DAYS_LEAPMONTHs[nMonth]; nMonth++)
    			 nDaysOver = (nDaysOver - DAYS_LEAPMONTHs[nMonth]);
    			 if(nMonth == 12)
    			      nMonth = 1;
    			      nYear ++;
    		    nDay = nDaysOver;
    	       else
    		    nDay = nDaysOver + nDay;
    	  else
    	       if((nDaysOver + nDay) > DAYS_MONTHs[nMonth])
    		    nDaysOver = nDaysOver - (DAYS_MONTHs[nMonth] - nDay);
    		    nMonth++;
    		   for(nMonth = nMonth; nDaysOver > DAYS_MONTHs[nMonth]; nMonth++)
    			 nDaysOver = (nDaysOver - DAYS_MONTHs[nMonth]);
    			 if(nMonth == 12)
    			      nMonth = 1;
    			      nYear ++;
    		    nDay = nDaysOver;
    	       else
    	  c24HrTime = fnConv_SecondsTo24HrTime(nSecondsRemain);
         else
    	  c24HrTime = fnConv_SecondsTo24HrTime(nTotalTimeSeconds);
         cNewDate = "right_string("'0',ITOA(nMonth)",2),'/',right_string("'0',ITOA(nDay)",2),'/',right_string("'0',ITOA(nYear)",2)";
         RETURN "DAY_OF_WEEK_ABREV[TYPE_CAST(DAY_OF_WEEK(cNewDate))],', ',itoa(nDay),' ',MONTH_OF_YR_ABREV[nMonth],' ',itoa(nYear),' ',c24HrTime";
    DEFINE_FUNCTION fnFB_Time(INTEGER iUI_Indx,INTEGER iEvent) //<< SET VT ADDRESS CHANNELS  CHANGE SETTING PER JOB **********************>>>
         SWITCH(iEvent)
    	  CASE FB_TIME_TIME:
    	       //panels can handle time on their own
    	  CASE FB_TIME_SUNRISE:
    	       fnFB_TimeSend_VT(iUI_Indx,BTN_VT_SUNRISE,"'Sunrise at ',itoa(sMyTime.nSunriseHour),':',itoa(sMyTime.nSunriseMinute),' AM'");
    	  CASE FB_TIME_SUNSET:
    	       fnFB_TimeSend_VT(iUI_Indx,BTN_VT_SUNSET,"'Sunset at ',itoa(sMyTime.nSunset12Hour),':',itoa(sMyTime.nSunsetMinute),' PM'");
    	  CASE FB_TIME_DST:
    	       if(sMyDST.nDST_Active)
    		    //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: IN EFFECT'");
    	       else
    		    //fnFB_TimeSend_VT(iUI_Indx,??,"'DST: NOT IN EFFECT'");
    	  CASE FB_TIME_HOLIDAY:
    	       fnFB_TimeSend_VT(iUI_Indx,BTN_VT_HOLIDAY,"sMyTime.cHoliday");
    DEFINE_FUNCTION fnFB_TimeSend_VT(INTEGER iUI_Indx,INTEGER iCHAN,CHAR iStrMSG[500])
         STACK_VAR INTEGER n;
         STACK_VAR INTEGER nTPCount;
         STACK_VAR INTEGER nLoopStart;
         if(iUI_Indx)
    	  nTPCount = iUI_Indx;
    	  nLoopStart = iUI_Indx;
         else
    	  nTPCount = NUM_UIs_IN_SYSTEM;
    	  nLoopStart = 1;
         //fnTime_DeBug("'SEND_VT: ',iStrMSG,' :DEBUG <',itoa(__LINE__),'>'");
         for(n = nLoopStart; n <= nTPCount; n++)
    	  SWITCH(nUI_TypeArry[n])
    	       CASE UI_TYPE_G4:
    	       CASE UI_TYPE_R4:
    	       CASE UI_TYPE_MIO_DMS:
    	       (* no need for uni strings!!!
    		    STACK_VAR WIDECHAR cSTRING1[500];
    		    STACK_VAR CHAR cSTRING2[500];
    		    cSTRING1 = WC_DECODE(iStrMSG,WC_FORMAT_UTF8,1);
    		    cSTRING2 = WC_ENCODE(cSTRING1,WC_FORMAT_TP,1);
    		    //fnTime_DeBug("'^UNI- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'");
    		    SEND_COMMAND dvUI_Arry[n], "'^UNI-',itoa(iCHAN),',0,',cSTRING2";
    	       CASE UI_TYPE_G3:
    	       CASE UI_TYPE_iPHONE://uni not supported yet
    	       CASE UI_TYPE_iPAD:
    	       CASE UI_TYPE_iTOUCH:
    		    //fnTime_DeBug("'^TXT- TP INDX: ',itoa(n),', CHNL: ',itoa(iCHAN),' :DEBUG <',ITOA(__LINE__),'>'");
    		    SEND_COMMAND dvUI_Arry[n], "'TEXT',itoa(iCHAN),'-',iStrMSG";
    	       CASE UI_TYPE_METKP:
    	       CASE UI_TYPE_UNKNOWN:
    	       CASE UI_TYPE_VIRTUAL:
    		    //DO NOTHING
         RETURN;
    DEFINE_FUNCTION fnTime_DeBug(CHAR iStr[])
         if(nTime_DeBug)
    	  STACK_VAR CHAR cCopyStr[1024];
    	  STACK_VAR INTEGER nLineCount;
    	  cCopyStr = iStr;
    	  nLineCount ++;
    	  WHILE(length_string(cCopyStr) > 100)
    	       SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',get_buffer_string(cCopyStr,100)";
    	       nLineCount ++;
    	  if(length_string(cCopyStr))
    	       SEND_STRING 0,"'TIME DEBUG (',itoa(nLineCount),'): ',cCopyStr";
         RETURN;
    DEFINE_FUNCTION fnGet_DST_State()
         {//don't care about the hour of day it actually occurs!
         fnTime_DeBug("'fnCheckDST_Rule(): Checking DST State :DEBUG <',ITOA(__LINE__),'>'");
         SELECT
    	  ACTIVE(sMyTime.nMonth < DST_BEGIN_MONTH || sMyTime.nMonth > DST_END_MONTH):
    	       {//quick elimination
    	       sMyDST.nDST_Active = 0;
    	  ACTIVE(sMyTime.nMonth > DST_BEGIN_MONTH && sMyTime.nMonth < DST_END_MONTH):
    	       sMyDST.nDST_Active = 1;
    	  ACTIVE(sMyTime.nMonth == DST_BEGIN_MONTH):
    	       if(sMyTime.nDayOccurance[sMyDST.nBEG_Day] >= sMyDST.nBEG_DAY_Occurance)
    	       else
    	  ACTIVE(sMyTime.nMonth == DST_END_MONTH):
    	       if(sMyTime.nDayOccurance[sMyDST.nEND_Day] >= sMyDST.nEND_DAY_Occurance)
    	       else
    	  ACTIVE(TRUE):
    	       fnTime_DeBug("'fnCheckDST_Rule(): DST Check Error! :DEBUG <',ITOA(__LINE__),'>'");
    	       RETURN;
    	  fnTime_DeBug("'fnCheckDST_Rule(): DST is Active! :DEBUG <',ITOA(__LINE__),'>'");
         else
    	  fnTime_DeBug("'fnCheckDST_Rule(): DST is In-Active! :DEBUG <',ITOA(__LINE__),'>'");
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_DST);
         RETURN;
    DEFINE_FUNCTION fnGet_AstroClock()
         LOCAL_VAR SINTEGER nTimeMngr_Result;
         fnTime_DeBug("'fnAstro_Clock(): Running ArtoClock! :DEBUG <',ITOA(__LINE__),'>'");
         sGet_ClkMgr.cTimeZone = CLKMGR_GET_TIMEZONE();
         sGet_ClkMgr.nReSyncPeriod = CLKMGR_GET_RESYNC_PERIOD();
         sGet_ClkMgr.nIs_DST_On = CLKMGR_IS_DAYLIGHTSAVINGS_ON();// this only return whether it's observed or not not if it's active, very stupid!
         sGet_ClkMgr.cDST_EndRule = CLKMGR_GET_END_DAYLIGHTSAVINGS_RULE();
         sGet_ClkMgr.cDST_StartRule = CLKMGR_GET_START_DAYLIGHTSAVINGS_RULE();
         CLKMGR_GET_TIMESERVERS(sGet_ClkMgr.sTimeServers);
         CLKMGR_GET_DAYLIGHTSAVINGS_OFFSET(sGet_ClkMgr.sOffset);
         CLKMGR_GET_ACTIVE_TIMESERVER(sGet_ClkMgr.sActiveTimeServer);
         if(sMyDST.nObserved)
    	  fnGet_DST_State();
         //SINTEGER ASTRO_CLOCK(DOUBLE Longitude,DOUBLE Latitude,DOUBLE HoursFromGMT,CHAR[] Date,CHAR[] Sunrise,CHAR[] Sunset)
         if(sMyDST.nDST_Active)//
    	  nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EDT,LDATE,sMyTime.cSunrise,sMyTime.cSunset);
         else
    	  nTimeMngr_Result = ASTRO_CLOCK(CLKMGR_LAT,CLKMGR_LONG,CLKMGR_OFFSET_GMT_EST,LDATE,sMyTime.cSunrise,sMyTime.cSunset);
         fnTime_DeBug("'fnAstro_Clock(): Sunset Time = ',sMyTime.cSunset,' :DEBUG <',ITOA(__LINE__),'>'");
         sMyTime.nSunset24Hour = atoi(left_string(sMyTime.cSunset,2));
         sMyTime.nSunsetMinute = atoi(mid_string(sMyTime.cSunset,4,2));
         sMyTime.nSunsetSecond = atoi(right_string(sMyTime.cSunset,2));
         sMyTime.nSunsetTime   =  ((((sMyTime.nSunset24Hour * 60) + sMyTime.nSunsetMinute) * 60) + sMyTime.nSunsetSecond);
         if(sMyTime.nSunset24Hour >= 12)
    	  sMyTime.nSunset12Hour = sMyTime.nSunset24Hour - 12;
         else//yeah, I know!
    	  sMyTime.nSunset12Hour = sMyTime.nSunset24Hour;
         fnTime_DeBug("'fnAstro_Clock(): Sunrise Time = ',sMyTime.cSunrise,' :DEBUG <',ITOA(__LINE__),'>'");
         sMyTime.nSunriseHour   = atoi(left_string(sMyTime.cSunrise,2));
         sMyTime.nSunriseMinute = atoi(mid_string(sMyTime.cSunrise,4,2));
         sMyTime.nSunriseSecond = atoi(right_string(sMyTime.cSunrise,2));
         sMyTime.nSunriseTime   = ((((sMyTime.nSunriseHour * 60) + sMyTime.nSunriseMinute) * 60) + sMyTime.nSunriseSecond);
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNRISE);
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_SUNSET);
    DEFINE_FUNCTION fnGet_DayOccurrences()
         if(sMyTime.nDayOfWeek && sMyTime.nDayOfMonth)
    	  STACK_VAR INTEGER nD_O_W;
    	  sMyTime.nWeekOfMonth = sMyTime.nDayOfMonth / 7;
    	  sMyTime.nPlusDays  = sMyTime.nDayOfMonth % 7;
    	  for(i = 1; i <= 7; i ++)//first erase stored values
    	       sMyTime.nDayOccurance[i] = 0;
    	  nD_O_W = sMyTime.nDayOfWeek;
    	  sMyTime.nDayOccurance[nD_O_W] ++;
    	  for(i = sMyTime.nDayOfMonth; i > 1; i --)
    	       if(nD_O_W > 1)
    		    nD_O_W --;
    	       else
    		    nD_O_W = 7;
    	  fnTime_DeBug("'fnFindDayOccurences(): The First Day of the Month= ',DAY_OF_WEEK_ABREV[nD_O_W],' (',itoa(nD_O_W),') :DEBUG <',ITOA(__LINE__),'>'");
    	  fnTime_DeBug("'fnFindDayOccurences(): Weeks= ',itoa(sMyTime.nWeekOfMonth),', Days= ',itoa(sMyTime.nPlusDays),
    			 ', Day= ',itoa((sMyTime.nWeekOfMonth * 7) + sMyTime.nPlusDays),' of ',MONTH_OF_YR_ABREV[sMyTime.nMonth],' :DEBUG <',ITOA(__LINE__),'>'");
         else
    	  fnTime_DeBug("'fnFindDayOccurences(): Error! No Value in sMyTime.nDayOfWeek or sMyTime.nDayOfMonth :DEBUG <',ITOA(__LINE__),'>'");
    DEFINE_FUNCTION fnGet_Holiday()
         sMyTime.cHoliday = '';
         SWITCH(sMyTime.nMonth)
    	  CASE JANUARY:
    	       SELECT
    		    ACTIVE(sMyTime.nDayOfMonth == 1):
    			 sMyTime.cHoliday = 'New Years Day';
    		    ACTIVE(sMyTime.nDayOccurance[MONDAY] == THIRD && sMyTime.nDayOfWeek == MONDAY):
    			 sMyTime.cHoliday = "'M.L.King',39,'s Birthday'";
    	  CASE FEBRUARY:
    	       SELECT
    		    ACTIVE(sMyTime.nDayOfMonth == 2):
    			 sMyTime.cHoliday = 'Ground Hog Day';
    		    ACTIVE(sMyTime.nDayOfMonth == 14):
    			 sMyTime.cHoliday = "'Valentine',39,'s Day'";
    		    ACTIVE(sMyTime.nDayOfMonth == 22):
    			 sMyTime.cHoliday = "'G. Washington',39,'s Birthday'";
    			 sMyTime.cHoliday = "'President',39,'s Day'";
    	  CASE MARCH:
    	       SELECT
    		    ACTIVE(sMyTime.nDayOfMonth == 9):
    			 sMyTime.cHoliday = "'Employee Appreciation Day'";
    		    //ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14):
    //			 sMyTime.cHoliday = "'Aniversary in ',itoa(14-sMyTime.nDayOfMonth),' days'";
    //		    ACTIVE(sMyTime.nDayOfMonth >= 10 && sMyTime.nDayOfMonth < 14):
    //			 sMyTime.cHoliday = "'Steve & Jojo''s ',itoa(sMyTime.nYear - 1984),'th Aniversary!'";
    		    ACTIVE(sMyTime.nDayOfMonth == 17):
    			 sMyTime.cHoliday = "'ST Patrick',39,'s Day'";
    	       //EASTER?
    	  CASE APRIL:
    	       SELECT
    			 sMyTime.cHoliday = "'April Fool',39,'s Day'";
    			 sMyTime.cHoliday = "'Patriot',39,'s Day'";
    	  CASE MAY:
    	       SELECT
    		    ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth < 5):
    			 sMyTime.cHoliday = "'Martha''s birthday in ',itoa(5-sMyTime.nDayOfMonth),' days'";
    			 sMyTime.cHoliday = "'Martha''s birthday!'";
    		    ACTIVE(sMyTime.nDayOccurance[SUNDAY] == SECOND && sMyTime.nDayOfWeek == SUNDAY):
    			 sMyTime.cHoliday = "'Mother''s Day'";
    		    ACTIVE(sMyTime.nDayOccurance[SATURDAY] == THIRD && sMyTime.nDayOfWeek == SATURDAY):
    			 sMyTime.cHoliday = "'Armed Forces Day'";
    		    ACTIVE(sMyTime.nDayOccurance[MONDAY] == FOURTH && sMyTime.nDayOfMonth > 24 && sMyTime.nDayOfWeek == MONDAY):
    			 sMyTime.cHoliday = 'Memorial Day';
    		    ACTIVE(sMyTime.nDayOccurance[MONDAY] == FIFTH && sMyTime.nDayOfWeek == MONDAY):
    	  CASE JUNE:
    	       SELECT
    			 sMyTime.cHoliday = "'Flag Day'";
    		    ACTIVE(sMyTime.nDayOfMonth == 21):
    			 sMyTime.cHoliday = "'Summer Solstice'";
    		    ACTIVE(sMyTime.nDayOccurance[SUNDAY] == THIRD && sMyTime.nDayOfWeek == SUNDAY):
    			 sMyTime.cHoliday = "'Father',39,'s Day'";
    	  CASE JULY:
    	       if(sMyTime.nDayOfMonth == 4)
    		    sMyTime.cHoliday = 'Independence Day';
    	  CASE AUGUST:
    	       if(sMyTime.nDayOccurance[SUNDAY] == FIRST && sMyTime.nDayOfWeek == SUNDAY)
    		    sMyTime.cHoliday = "'Friendship Day'";
    	  CASE SEPTEMBER:
    	       if(sMyTime.nDayOccurance[MONDAY] == FIRST && sMyTime.nDayOfWeek == MONDAY)
    		    sMyTime.cHoliday = 'Labor Day';
    	  CASE OCTOBER:
    	       if(sMyTime.nDayOfMonth == 31)
    		    sMyTime.cHoliday = 'Halloween';
    	  CASE NOVEMBER:
    	       SELECT
    			 sMyTime.cHoliday = "'All Saint',39,'s Day'";
    		    ACTIVE(sMyTime.nDayOfMonth == 11):
    			 sMyTime.cHoliday = "'Veteran',39,'s Day'";
    		    ACTIVE(sMyTime.nDayOccurance[THURSDAY] == FOURTH && sMyTime.nDayOfWeek == THURSDAY):
    			 sMyTime.cHoliday = 'Thanksgiving Day';
    	  CASE DECEMBER:
    	       SELECT
    		    ACTIVE(sMyTime.nDayOfMonth >= 1 && sMyTime.nDayOfMonth <= 23):
    			 sMyTime.cHoliday = "ITOA(25 - sMyTime.nDayOfMonth),' days to Christmas'";
    			 sMyTime.cHoliday = 'Winter Solstice';
    		    ACTIVE(sMyTime.nDayOfMonth == 24):
    			 sMyTime.cHoliday = 'Christmas Eve';
    		    ACTIVE(sMyTime.nDayOfMonth == 25):
    			 sMyTime.cHoliday = 'Christmas Day';
    		    ACTIVE(sMyTime.nDayOfMonth == 31):
    			 sMyTime.cHoliday = "'New Year',39,'s Eve'";
         if(length_string(sMyTime.cHoliday))
    	  sMyTime.cHoliday = "'[ ',sMyTime.cHoliday,' ]'";
    	  fnTime_DeBug("'fnFindHolidays(): Today is ',sMyTime.cHoliday,' :DEBUG <',ITOA(__LINE__),'>'");
         else
    	  fnTime_DeBug("'fnFindHolidays(): Today is not a "supported" holiday! :DEBUG <',ITOA(__LINE__),'>'");
         fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_HOLIDAY);
         RETURN;
    DEFINE_FUNCTION fnGet_WebDATE_TIME()
         sMyTime.cWebCurDateTime = "fnDo_24hrTimeAddition(LDate,TIME,0),' EST'";
         sMyTime.cWebExpDateTime = "fnDo_24hrTimeAddition(LDate,TIME,EXPIRES_IN_SECONDS),' EST'";
         RETURN;
    DEFINE_FUNCTION fnRun_SunRise_Set(INTEGER iDaytime)
         //SWITCH(iDaytime)
    //	  CASE 0:{} //night
    //	  CASE 1:{} //day
         fnMain_SunRise_Set(iDaytime);
    DEFINE_FUNCTION fnRun_D_O_W_Events(INTEGER iDayOfWeek)   //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyDOW;
         nCopyDOW = iDayOfWeek;
         //SELECT ACTIVE or SWITCH CASE to do something
    DEFINE_FUNCTION fnRun_D_O_M_Events(INTEGER iDayOfMonth)  //<<**************  CHANGE SETTING PER JOB **********************************>>>
         {//uncomment call in fnUpdate_Time()
         STACK_VAR INTEGER nCopyDOM;
         nCopyDOM  = iDayOfMonth;
    DEFINE_FUNCTION fnRun_DailyEvents()                      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         //fnDailyEmailTest();
         fnGet_Holiday();
         fnGet_AstroClock();
         fnMain_EveryDay();
    DEFINE_FUNCTION fnRun_HourEvents(INTEGER iHour)          //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyHour;
         nCopyHour  = iHour;
         fnMain_EveryHour(nCopyHour);
    DEFINE_FUNCTION fnRun_MinuteEvents(INTEGER iMinute)      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopyMinute;
         nCopyMinute  = iMinute;
         fnMain_EveryMinute(nCopyMinute);
    DEFINE_FUNCTION fnRun_SecondEvents(INTEGER iSecond)      //<<**************  CHANGE SETTING PER JOB **********************************>>>
         STACK_VAR INTEGER nCopySecond;
         nCopySecond = iSecond;
         fnMain_EverySecond(nCopySecond);
    DEFINE_FUNCTION fnRun_StartUpCode()
         LOCAL_VAR CLKMGR_TIMEOFFSET_STRUCT sMyCLKMGR_TIMEOFFSET;
         fnTime_DeBug("'fnRunStartUpCode(): Run Start Up! :DEBUG <',ITOA(__LINE__),'>'");
         sMyDST.nObserved = DST_OBSERVED;
    	  sMyDST.nOffset	= DST_OFFSET;
    	  sMyDST.nBEG_Month	= DST_BEGIN_MONTH;
    	  sMyDST.nEND_Month     = DST_END_MONTH;
    	  sMyDST.nBEG_Day       = DST_BEGIN_DAY;
    	  sMyDST.nEND_Day 	= DST_END_DAY;
    	  sMyDST.nBEG_DAY_Occurance = DST_BEGINDAY_OCCURANCE;
    	  sMyDST.nEND_DAY_Occurance = DST_ENDDAY_OCCURANCE;
         WAIT 300//3000
    	  fnTime_DeBug("'fnRunStartUpCode(): Run Start Up Wait items! :DEBUG <',ITOA(__LINE__),'>'");
    	  CLKMGR_SET_CLK_SOURCE(CLKMGR_MODE_NETWORK); // or CLKMGR_MODE_STANDALONE
    	  CLKMGR_SET_ACTIVE_TIMESERVER (CLKMGR_ACTIVESERVER);
    	  CLKMGR_SET_TIMEZONE(CLKMGR_TIME_ZONE);
    	  CLKMGR_SET_DAYLIGHTSAVINGS_MODE(TRUE);//moved to DST function
    	  CLKMGR_SET_START_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_BEGINDAY_OCCURANCE),',',itoa(DST_BEGIN_DAY),',',itoa(DST_BEGIN_MONTH),',',DST_BEGIN_TIME" );
    	  CLKMGR_SET_END_DAYLIGHTSAVINGS_RULE("'occurrence:',itoa(DST_ENDDAY_OCCURANCE),',',itoa(DST_END_DAY),',',itoa(DST_END_MONTH),',',DST_END_TIME" );
    	  CLKMGR_SET_RESYNC_PERIOD(CLKMGR_RESYNC_PERIOD);
    	  sMyCLKMGR_TIMEOFFSET.HOURS   = CLKMGR_DST_OFFSET_HR;
    	  sMyCLKMGR_TIMEOFFSET.MINUTES = CLKMGR_DST_OFFSET_MIN;
    	  sMyCLKMGR_TIMEOFFSET.SECONDS = CLKMGR_DST_OFFSET_SEC;
    	  CLKMGR_SET_DAYLIGHTSAVINGS_OFFSET(sMyCLKMGR_TIMEOFFSET);
    	  nTimeWait_Force = 2;
    	  fnUpdate_Time();
         if(!TIMELINE_ACTIVE(TL_TIME))
    	  TIMELINE_CREATE(TL_TIME,nTL_TIME_RT,1,timeline_absolute,timeline_repeat);
    DEFINE_FUNCTION fnUpdate_Time()
         if(sMyTime.nSecond != TYPE_CAST(TIME_TO_SECOND(TIME)) || nTimeWait_Force)
    	  sMyTime.nSecond = TYPE_CAST(TIME_TO_SECOND(TIME));
    	  sMyTime.c24Time = TIME;
    	  if(sMyTime.nMinute != TYPE_CAST(TIME_TO_MINUTE(TIME)) || nTimeWait_Force)
    	       sMyTime.nMinute = TYPE_CAST(TIME_TO_MINUTE(TIME));
    	       //only 1 minute resolution for sunrise/set, could check every second but why, not that critical.....
    	       if(sMyTime.nTime_Seconds >= sMyTime.nSunriseTime && sMyTime.nTime_Seconds < sMyTime.nSunsetTime)
    		    if(!sMyTime.nDaytime)
    			 sMyTime.nDaytime = 1;
    			 fnRun_SunRise_Set(sMyTime.nDaytime);
    	       else
    		    if(sMyTime.nDaytime)
    			 sMyTime.nDaytime = 0;
    	       if(sMyTime.n24Hour != TYPE_CAST(TIME_TO_HOUR(TIME)) || nTimeWait_Force)
    		    sMyTime.n24Hour = TYPE_CAST(TIME_TO_HOUR(TIME));
    		    if(sMyTime.n24Hour >= 12)
    			 sMyTime.cAMPM = 'PM';
    			 sMyTime.nTimePM_flag = 1;
    			 if(sMyTime.n24Hour > 12)
    			      sMyTime.n12Hour = sMyTime.n24Hour - 12;
    			 else
    			      sMyTime.n12Hour = sMyTime.n24Hour;
    		    else
    			 sMyTime.cAMPM = 'AM';
    			 sMyTime.nTimePM_flag = 0;
    		    sMyTime.c12Time = "itoa(sMyTime.n12Hour),':',RIGHT_STRING("'0',itoa(sMyTime.nMinute)",2),':',RIGHT_STRING("'0',itoa(sMyTime.nSecond)",2)";
    		    if(sMyTime.nDayOfMonth != TYPE_CAST(DATE_TO_DAY(LDATE)) || nTimeWait_Force)
    			 sMyTime.nDayOfMonth = TYPE_CAST(DATE_TO_DAY(LDATE));
    			 sMyTime.nDayOfWeek = TYPE_CAST(DAY_OF_WEEK(LDATE));
    			 if(sMyTime.nMonth != TYPE_CAST(DATE_TO_MONTH(LDATE)))//no force here.  would erase stored values.
    			      sMyTime.nMonth = TYPE_CAST(DATE_TO_MONTH(LDATE));
    			      if(sMyTime.nYear != TYPE_CAST(DATE_TO_YEAR(LDATE)))
    				   sMyTime.nYear = TYPE_CAST(DATE_TO_YEAR(LDATE));
    			 if(sMyTime.cDay != Day || nTimeWait_Force)
    			      sMyTime.cDay = Day;
    			      if (sMyTime.cDate != Date)
    				   sMyTime.cDate = Date;
    			 fnGet_DayOccurrences();
    			 fnRun_D_O_W_Events(sMyTime.nDayOfWeek);
    			 fnRun_D_O_M_Events(sMyTime.nDayOfMonth);
    			 fnRun_DailyEvents();
    		    fnRun_HourEvents(sMyTime.n24Hour);
    	       else
    	       sMyTime.nTime_Minutes = ((sMyTime.n24Hour * 60) + sMyTime.nMinute);
    	       fnRun_MinuteEvents(sMyTime.nMinute);
    	  else
    	  sMyTime.nTime_Seconds = ((((sMyTime.n24Hour * 60) + sMyTime.nMinute) * 60) + sMyTime.nSecond);
    	  fnRun_SecondEvents(sMyTime.nSecond);
    	  fnFB_Time(UI_UPDATE_ACTIVE,FB_TIME_TIME); //IF ANYTHING NEEDS TIME UPDATES
         nTimeWait_Force  = 0;
    DEFINE_START    //RUN START UP CODE
    fnRun_StartUpCode();
    DEFINE_EVENT    //TIMELINE_EVENT [TL_TIME]
    TIMELINE_EVENT [TL_TIME]//EVERY 250ms
         fnUpdate_Time();
         fnMain_250ms_Clock();//put any other timing events in the main in this function
    DEFINE_PROGRAM  //CALL fnUpdate_Time() if you don't have a timeline elsewhere to call it every second
    WAIT 10
         fnUpdate_Time();
    John_Glove wrote: »
    hi all
    example:
    ON:
    Try (LDATE) instead of (DATE)
  • hi
    thanks for the code!
    i have on all my system's at home this compare_string for minute/hour/day/month/year. this works for a long time without no problem, so i don't want to change them.
    the cmd: nDAY = DAY_OF_WEEK (DATE) works on other event's like startup. and gives me the correct day back.
    only in the specified channel_event it doesn't works. that's what i didn't understand
    the cmd works and the channel_event is triggered, but together.....
    that's my question ;-)
    For fun and testing purposes I ran this code on my master:
    Button_Event[dvTP,1]
    	Push: Pulse[vdvDevice,3]
    Channel_Event[vdvDevice,3]
    	On:
    		nDay = 999 // So we can tell if nothing happened
    		// Using DATE
    		Send_String 0,"'nDAY=',Itoa(nDay),' DAY_OF_WEEK(DATE)=',Itoa(DAY_OF_WEEK(DATE))"
    		// Using LDATE
    		nDay = DAY_OF_WEEK (LDATE)
    		Send_String 0,"'nDAY=',Itoa(nDay),' DAY_OF_WEEK(LDATE)=',Itoa(DAY_OF_WEEK(LDATE))"
    And this was the output when I did the button push:
    (0000118402) nDAY=5 DAY_OF_WEEK(DATE)=5
    (0000118403) nDAY=5 DAY_OF_WEEK(LDATE)=5
    So, doing those functions in a channel event is not inherently broken on the AMX side.
    Instead of linking it to a channel event (which seems to be the sticking point), put this in a timeline, or in mainline:
    IF (sDate <> DATE)
    {   // stuff to happen when the day changes
         nDAY = DAY_OF_WEEK (DATE) ;
         sDate = DATE ;
    ... where sDate is a globally defined CHAR array. I make it a nonvolatile variable so a reboot won't force the event.
  • so i have the solution working (for me):
    with the nDay variable i make some channel_event's (one channel for every_day)
    thanks for all the help!
    john
