Biamp NEXIA Routing functions
Hi everyone.
I'm trying to implement the command RTRMUTEXP into a Project but I'm not quite sure if the Duet module supports it.
Can someone help?
Thks
    Not at my laptop to check but you can always send the command yourself with the PASSTHRU-
    AMXJeffAMXJeff Posts: 450
    Hi everyone.
    Can someone help?
    Thks
    AI<input>O<output>[,<output>]
    Switch the specified input channel to the specified output channel(s) at the audio level. Use the mapped virtual port when sending this command.
    (MaxInputs and MaxOutputs are set when using the “AUDIOPROCADD-“ command for Crosspoints and Switcher Types.)
    <input> : 0 = disconnect input channel
    or 1-MaxInputs = input channel
    <output> : 1-MaxOutputs = output channel
    AI3O4
    AI0O6
    AI5O7,1,3
    <Switcher Type Only: >
    **Biamp Special Component: ROUTER.CROSSPOINT.ALL
