NXT-1500VG & MXT-700 Firmware
Been working as a freelance programmer on AMX projects since 2001. The dealer I worked through recently lost their AMX dealership and with it my access to firmware and application files on the AMX Tech site. I am supporting a couple of projects where I need to upgrade touchpanel firmware specifically on NXT-1500VG and MXT-700 panels. I need v2.86.23 for the NXT-1500VG and v2.104.43 for the MXT-700 X-series panel. If anyone can help out, feel free to PM me. Thanks.
    Was able to get the needed firmware files to update the panels. Thanks for everyone that offered to help!
    You should be able to register with AMX as and independent programmer so this won't happen to you again. Not being a dealer, I'm not sure you could purchase anything, but at least you will have software / firmware access.
    DHawthorne wrote: »
    Yeah, purchasing gear is verboten.. but you do get access to all the other goodies such as access and file downloads. I do get calls from outsiders looking to simply purchase gear or replace stuff where the dealer has gone away. In those cases I just work with one of the local dealers in the area of the cleint and we seem to be able to usually come up with a solution.
    My experience as a VIP has been positive overall. Like anything it has its unexpected challenges. But, it would be worth looking into.
