Virtual Device ports
cmasoncmason Junior MemberPosts: 123
I'm a bit confused. Everywhere on the forum and Netlinx help it is stated virtual devices have only one port (unless adjusted by SET_VIRTUAL_PORT_COUNT).
I made a quick test code:
PROGRAM_NAME='Test'
vdvDevice1	=	33001:1:0
vdvDevice2	=	33001:2:0
CHANNEL_EVENT[vdvDevice1,1]
    ON:
	SEND_STRING 0, "'Port 1'"
CHANNEL_EVENT[vdvDevice2,1]
    ON:
	SEND_STRING 0, "'Port 2'"
I pulsed both of the channels I defined and here is the DIAG ouput:
Line      1 (15:03:31.994)::  Port 1
Line      2 (15:03:31.994)::  Memory Available = 208963064 <18624>
Line      3 (15:03:36.850)::  Port 2
Why did it work?
  • GregGGregG Just some guy... Posts: 249
    Ports are automatically created for virtual devices when they are defined in DEFINE_START - If they are sequential and start from port 1.
    The main reasons to define them using SET_VIRTUAL_PORT_COUNT are if you will be using just higher port numbers without defining the lower ones, or if you will be calculating the ports in code and don't want to list them all in advance.
    As far as I can recall, I have never run into a case where I needed to use SET_VIRTUAL_PORT_COUNT.
  • rfletcherrfletcher Junior Member Posts: 217
    GregG wrote: »
    If this is true now I don't think it used to be.
    I had an issue way back when I first started programming with higher number virtual ports without calling set_virtual_port_count. Things like pushes worked but iirc levels and possibly feedback did not function correctly and the additional ports did not actually show up in the device tree. It's possible this has been changed though as that was maybe 8-9 years ago at this point (which is a terrifying thought).
    I'm curious if your additional ports are there without using set_virtual_port_count so let us know :)
  • TechFreakTechFreak Junior Member Posts: 39
    If I recall correctly, by default there are 8 ports and 8 levels that are accessible on virtual devices, anything over 8 needs to be explicitly set using SET_VIRTUAL_PORT_COUNT or LEVEL_COUNT. This is the same for channels, anything over 255 needs to be set with SET_VIRTUAL_CHANNEL_COUNT
    Frank Krauch, AMX ACE
    This works for both port 8 and port 9 on an NI700 and an NX1200 (and as far as I have experienced, always worked back to the time of the NXI):
    vdvDevice3 = 33001:3:0
    vdvDevice4 = 33001:4:0
    vdvDevice5 = 33001:5:0
    vdvDevice6 = 33001:6:0
    vdvDevice7 = 33001:7:0
    vdvDevice8 = 33001:8:0
    vdvDevice9 = 33001:9:0
    Channel_Event[vdvDevice8,1]
    	On: Send_String 0,'Port 8 - On'
    Channel_Event[vdvDevice9,1]
    	On: Send_String 0,'Port 9 - On'
    And this also works on both masters (which I didn't expect, so it might be a new v4+ firmware feature):
    I tried to downgrade to 3.x firmware in the NI700, but apparently that isn't supported. If I remember sometime over the weekend I'll give it a shot against an old NXI I have hanging around.
  • cmasoncmason Junior Member Posts: 123
    Interesting.
    Thanks for the responses.
    I thought that defining them might have made the difference, but all of the documentation I have read, seemed so adamant about the limitations and never mentioned "unless defined".
    Perhaps AMX should/will generate definitive updated documentation about the current limitations on Ports, Channels, and levels.
  • nicholasjamesnicholasjames Junior Member Posts: 154
    From my experience, if using a device with a port greater than 1 as the lone device in an event, such as I've seen from the examples posted so far in this thread, NetLinx does "create" it as one would expect. However, if used in an array or some other defined at runtime method, NetLinx isn't as copacetic.
  • Joe HebertJoe Hebert Junior Member Posts: 2,159
    Consider the following code:
    dvTP 		= 10001:1:0
    vdvPort1	= 33001:1:0
    vdvPort2	= 33001:2:0
    vdvPort3	= 33001:3:0
    DEV vdvPorts[] = {
       vdvPort1,
       vdvPort2,
       vdvPort3
    BUTTON_EVENT[dvTP,1] {PUSH: {SEND_STRING vdvPort1,"'Hey Port 1'"}}
    BUTTON_EVENT[dvTP,2] {PUSH: {SEND_STRING vdvPort2,"'Hey Port 2'"}}
    BUTTON_EVENT[dvTP,3] {PUSH: {SEND_STRING vdvPort3,"'Hey Port 3'"}}
    BUTTON_EVENT[dvTP,4] {PUSH: {SEND_STRING vdvPorts,"'Hey Ports'"}}
    Pushing Buttons 1,2,3 and 4 results in the following:
    Line      1 (11:32:47):: String To [33001:1:1]-[Hey Port 1]
    Line      2 (11:32:47):: String From [33001:1:1]-[Hey Port 1]
    Line      3 (11:32:51):: String To [33001:2:1]-[Hey Port 2]
    Line      4 (11:32:55):: String To [33001:3:1]-[Hey Port 3]
    Line      5 (11:32:58):: String To [33001:1:1]-[Hey Ports]
    Line      6 (11:32:58):: String From [33001:1:1]-[Hey Ports]
    Line      7 (11:32:58):: String To [33001:2:1]-[Hey Ports]
    Line      8 (11:32:58):: String To [33001:3:1]-[Hey Ports]
    Notice how only port 1 generates String To and String From.
    If you look at the online tree only 1 port shows up under 33001.
    Add the following code:
    SET_VIRTUAL_PORT_COUNT (vdvPort1,3)
    Line      1 (11:35:03):: String To [33001:1:1]-[Hey Port 1]
    Line      2 (11:35:03):: String From [33001:1:1]-[Hey Port 1]
    Line      3 (11:35:06):: String To [33001:2:1]-[Hey Port 2]
    Line      4 (11:35:06):: String From [33001:2:1]-[Hey Port 2]
    Line      5 (11:35:09):: String To [33001:3:1]-[Hey Port 3]
    Line      6 (11:35:09):: String From [33001:3:1]-[Hey Port 3]
    Line      7 (11:35:12):: String To [33001:1:1]-[Hey Ports]
    Line      8 (11:35:12):: String From [33001:1:1]-[Hey Ports]
    Line      9 (11:35:12):: String To [33001:2:1]-[Hey Ports]
    Line     10 (11:35:12):: String From [33001:2:1]-[Hey Ports]
    Line     11 (11:35:12):: String To [33001:3:1]-[Hey Ports]
    Line     12 (11:35:12):: String From [33001:3:1]-[Hey Ports]
    Notice that all 3 ports generate String To and String From.
    If you look at the online tree all 3 ports show up under 33001.
    There is clearly a difference when you use SET_VIRTUAL_PORT_COUNT and if you don’t use it things may work fine perfectly for your situation but I would recommend following the protocol and add the 1 line of code just to avoid any gotchas down the road.
  • NZRobNZRob Member Posts: 70
    Interestingly - I am using a 12 port module and it works every time - thought I had a SET_VIRTUAL_PORT_COUNT in it but just looked after reading this and I don't have one.
    That has been my past experience. If you don't set the virtual port count some things still work, but other things most definitely don't, and when you run into one of them it's a pain in the *** to figure out what's going on.
