Panasonic PT-LW330 Projector Power commands
Hi,
I am trying to control panasonic projector which is connected to DXLINK HDMI-RX (6004:1:2), where 2 is the DGX-16's system number.
When i am sending these commands:
send_string 6004:1:2,"$02,'PON',$03" //Power ON
send_string 6004:1:2,"$02,'POF',$03" //Power OFF
In FROM STRING of the device i am getting $E4,$E7 or G.
Not able to control the projector.. Does anyone tried any other commands? Do i need to change anything in the projectors menu using remote?
    Check that you have setup the correct baud rate. Sometimes the serial strings need a carriage return at the end of the string $0D.
    mritzmritz Posts: 22
    I believe that you are using the wrong baud rate. The older panasonic projectors and as I know all professional models are using 9600,N,8,1. All the newer and consumer models are using 19200,N,8,1.
    Here is what the manual says:
    Regards,
    Markus
    Thanks Markus.. Its working with 19200 baud.
