NetLinx commands for TP Design 4
IvanVTIvanVT Junior MemberPosts: 8
I would like to see the buttons for commands such as visible, active, opacity,... Are there any commands for the convenience of creating an interface?
  • vincenvincen Junior Member Posts: 526
    Did you check the touch panel documentation ? all send commands avalaible to interact with layout are listed there :)
  • IvanVTIvanVT Junior Member Posts: 8
    I have Ipad without touch panel! At iridium have functional for this commands. NetLinx, as I understand it, haven't functional.
  • John NagyJohn Nagy CineTouch Product Manager Posts: 1,654
    IvanVT wrote: »
    Then you don't actually understand it. Read the documentation.
    Can you take link to documentation?
    BUTTON_EVENT [dvPanel, 11]
    SEND_COMMAND dvPanel, "'^SHO-12.13&14.15,0'"
    -Is this commands?
    Code is not work for ipad (TPControl programming by TP Design 4). Are you understand?
    IvanVT wrote: »
    -Is this commands?
    Here's the command from the documentation.
    Show or hide a button with a set variable text range.
    Syntax:
    "'^SHO-<vt addr range>,<command value>'"
    Variable:
    variable text address range = 1 - 4000.
    command value = (0= hide, 1= show).
    Example:
    SEND_COMMAND Panel,"'^SHO-500.504&510.515,0'"
    Hides buttons with variable text address range 500-504 & 510-515.
    One common error I make in this regard is that I forget to assign the button an Address code. I put the channel code but forget to fill in the Address code. This is most common on buttons where I already have the text on the buttton and don't need variable text. None of the button commands will work unless you've assigned an Address code.
    I don't think the TP Contorl app has any issues with this command. It should work.
  • HARMAN_icraigieHARMAN_icraigie Technical Trainer II, Harman Professional University Posts: 593
    The ^SHO-...,x command and ^BMF-...,%SWx variant both work on TPControl without issues
