Sorting out variable conversion warnings ...
How do you get the compiler to stop whining about this?:
sinSum[x] = sinSum[x] + intAddend[y] * -1
Generates "WARNING: Converting type [SINTEGER] to [INTEGER] "
I tried:
sinSum[x] = sinSum[x] + TYPE_CAST(intAddend[y] * -1)
And:
sinSum[x] = sinSum[x] + TYPE_CAST(intAddend[y]) * TYPE_CAST(-1)
The compiler seems to whine no matter what I try.
Thanks for looking...
    How are you declaring intAddend[] and sinSum[]?
    The fact that you are multiplying intAddend by minus 1 implicitly converts it to an SINTEGER, and any operations on the result forces the result into an SINTEGER as well. There is a rule set to how internal typecasts are done for the purpose of operations, and not all of it is documented, so I have found it by far easier to make sure all my variables are of the same type inside an equation. If I need them to be something else later, I type_cast the *result* while assigning it to its final variable.
  • nickmnickm Posts: 152
    This compiles:
    sinSum[x] = sinSum[x] + TYPE_CAST(intAddend[y])  * -1
  • cmasoncmason Posts: 123
    Declarations:
    VOLATILE SINTEGER sinSum[]
    VOLATILE INTEGER intAddend[]
    nickm wrote: »
    This compiles:
    Thanks "nickm".
    I'm not sure why I didn't try that. Usually I stumble through how to apply TYPE_CAST. I cleaned a bunch of warnings up after reading a different tread addressing TYPE_CAST but the example I gave you just wouldn't go away.
    It's funny that "sinSum[x] = sinSum[x] + TYPE_CAST(intAddend[y]) * TYPE_CAST(-1)" dosen't work...
    yet "sinSum[x] = sinSum[x] + TYPE_CAST(intAddend[y]) * TYPE_CAST(25)" does.
    DHawthorne wrote: »
    I have gone back and converted INTEGERS (that didn't need to be) to SINTEGERS just to make the warnings go away. But then I would use those SINTEGERS elsewhere in my code and force new warnings, it seemed like would have to go back and convert more INTEGERS... spiraling out of control!
    Maybe I should just drop INTEGERS all together and only use SINTEGERS in place of all INTEGERS that are not likley to exceed 32,768?!?!?
    cmason wrote: »
    If you are going to need the sign at any point, that's not a bad solution.
    There is also the abs_value that forces sintegers to integers. But you do have an issue if your value is indeed a real negative number.
  • SLONG bug
    FYI, SLONG actually has a problem in the compiler that is a bug. See this post I made in another thread about SLONG type casting warnings. It has been reported to AMX...
