NI-3100 DNS LOOKUP FAILURE
fogled@mizzou
in AMX Hardware
I've got an NI-3100 controller that fails DNS lookup. I've double, triple, and quadruple-checked the DNS entries in the controller and the name of the host I'm trying to connect to, they are correct. Another controller in the same building on the same subnet has the exact same settings, and it works OK. But for some reason when I try to use a DNS name to do an IP_Client_Open, I get Error=4:Cannot find host. If I use the IP address instead of the name in IP_Client_Open, the controller connects to the server, but the server rejects the GET request I'm sending because security requires the hostname.
Any ideas? I'm stumped.
2) If you telnet into the master and ping google.com or ping the host name in question, what happens?
3) Are you populating a CHAR array for the host name at run-time? If so, are you sure the array is big enough to hold the entire name?
That’s strange. I’ve never heard of anything like that but then again there are a lot of things I haven’t heard of.
Aha! That's it! Never thought to look there. The hostname is kinda long, the container was 2 characters short of the actual hostname length.
Thanks!
In case you needed to communicate to a name-based host at an unpublished DNS name, for some reason.
