Cannot connect to Master
I am able to ping the Master using the host name, but I cannot telnet, ftp or get into the web server. It also will not connect in Netlinx, or using the listen function. The master is set to DHCP, and I can find it's IP address by pinging the host name. Any thoughts on how to connect to it?
  • GregGGregG Posts: 251
    Try setting the program disable dipswitch and power cycle it, then try to connect. Sometimes when code is insanely locked up they get wonky like that..
    There's also the programming port......
  • PhreaKPhreaK Posts: 966
    Your network infrastructure may also be blocking this. If you still can't hit those ports with PRD on I'd try and connect locally to rule this out if it's not a network you've deployed.
