Hold Button Event Issues by using own module
I am trying to do a hold event from a module and i am not able to work. But if i write the code without a module, it works perfectly. What am i doing wrong here. Please see my code examples.
1. Without module
2. With module
1. Without module
BUTTON_EVENT [dvSFLivingTP,btSerial_Plasma_6]
HOLD[2,REPEAT]:
SWITCH(get_last(btSerial_Plasma_6))
CASE 41:send_string dvSFLivingSerial_Plasma_3,"'LEFT00', $0D,$0A"// INCREASE VOLUME
CASE 42:send_string dvSFLivingSerial_Plasma_3,"'RGHT00', $0D,$0A"// DECREASE VOLUME
Release:
2. With module
PROGRAM_NAME='iSFLivingAquavisionTV'
#include 'iSFLivingSystemDevices.axi'
#include 'iSFLivingSystemVariables.axi'
DEFINE_MODULE 'Aquavision TV_Comm' AquavisionTV_Comm (dvSFLivingTP,
dvSFLivingSerial_Plasma_3,btSerial_Plasma_6,nAquavisionType)
DEFINE_EVENT // UI events
HOLD[2,REPEAT]:
CASE 41: DO_PUSH (dvSFLivingTP, 1152)
CASE 42:DO_PUSH (dvSFLivingTP, 1151)
Release:
CASE 41:DO_Release (dvSFLivingTP, 1152)
CASE 42:DO_Release (dvSFLivingTP, 1151)
MODULE_NAME='Aquavision TV_Comm'(DEV dvTP_DPS[],DEV dvDevice,integer nCHAN_BTN[],integer nType)
define_start
rebuild_event()
DATA_EVENT[dvDevice]
ONLINE:
send_command dvDevice,"'TSET BAUD 9600,N,8,1 485 disable'"
if(nType=2)
send_command dvDevice,"'CHARD-20'"
BUTTON_EVENT[dvTP_DPS,nCHAN_BTN]
Hold [2,REPEAT]:
if(nType==1)
switch(GET_LAST(nCHAN_BTN))
CASE 24:send_string dvDevice,"'RGHT00', $0D,$0A"// DECREASE VOLUME
CASE 25:send_string dvDevice,"'LEFT00', $0D,$0A"// INCREASE VOLUME
}else
CASE 24:send_string dvDevice,"'rght00', $0D,$0A"// DECREASE VOLUME
CASE 25:send_string dvDevice,"'left00', $0D,$0A"// INCREASE VOLUME
RELEASE:
if(nType==1)
}else
I probably use do_push timed more than do_push and often use 1 (1/10th second) for my time otherwise if I push a button that uses do_push and immediately release I can"t press and issue another push until the first push times out the default .5 seconds. That is of course unless your force the release with do_release which I always do too.
Example of my axi:
BUTTON_EVENT[dvUI_SBSArry,0] { PUSH : { STACK_VAR INTEGER nBtn; STACK_VAR INTEGER nSBS_Indx; STACK_VAR INTEGER nUI_Indx; STACK_VAR INTEGER i; nBtn = BUTTON.INPUT.CHANNEL; nUI_Indx = GET_LAST(dvUI_SBSArry); fnSBS_DeBug("'UI INDX-[ ',itoa(nUI_Indx),' ], SBS-[ ',itoa(nUI_SBSActiveArry[nUI_Indx]),' ], PUSH CHNL-[ ',itoa(nBtn),' ] :DEBUG<',ITOA(__LINE__),'>'"); if(nBtn <= 200) { if(nUI_SBSActiveArry[nUI_Indx] && nUI_SBSActiveArry[nUI_Indx] <= NUM_SBS_DEVICES)//not already going on or off page { nSBS_Indx = nUI_SBSActiveArry[nUI_Indx]; fnSBS_DeBug("'UI INDX-[ ',itoa(nUI_Indx),' ], SBS-[ ',itoa(nSBS_Indx),' ], PUSH CHNL-[ ',itoa(nBtn),' ] :DEBUG<',ITOA(__LINE__),'>'"); SELECT//could get rid of select/active since they are all the same action. { ACTIVE(nBtn == SBS_BTN_LVL_PUSH)://100level bar active {//push often lags the level event //ON[vSBS_Arry[nSBS_Indx],SBS_BTN_LVL_PUSH]; //just used in the .axi for level event verification //DO_PUSH_TIMED(vSBS_Arry[nSBS_Indx],nBtn,DO_PUSH_TIMED_10S_MAX); } ACTIVE(nBtn < SBS_BTN_REMOTE_SHUTDWON)://1-198Genral buttons { DO_PUSH_TIMED(vSBS_Arry[nSBS_Indx],nBtn,DO_PUSH_TIMED_10S_MAX); } ACTIVE(nBtn == SBS_BTN_REMOTE_SHUTDWON)://199 Send when Sever is no longer "on page and not sourced by any zone" shut down server { .... ..... RELEASE: { STACK_VAR INTEGER nBtn; STACK_VAR INTEGER nUI_Indx; STACK_VAR INTEGER nSBS_Indx; nBtn = BUTTON.INPUT.CHANNEL; nUI_Indx = GET_LAST(dvUI_SBSArry); nSBS_Indx = nUI_SBSActiveArry[nUI_Indx]; if(nSBS_Indx <= NUM_SBS_DEVICES) { fnSBS_DeBug("'UI INDX-[ ',itoa(nUI_Indx),' ], SBS-[ ',itoa(nSBS_Indx),' ], RELEASE CHNL-[ ',itoa(nBtn),' ] :DEBUG<',ITOA(__LINE__),'>'"); SELECT { ACTIVE(nBtn == SBS_BTN_LVL_PUSH)://level bar active { OFF[vSBS_Arry[nSBS_Indx],SBS_BTN_LVL_PUSH];//just used in the .axi for level event verification //DO_RELEASE(vSBS_Arry[nSBS_Indx],nBtn); } ACTIVE(nBtn < SBS_BTN_OFFPAGE):// || nBtn > SBS_BTN_ONPAGE_MAX)://all command buttons { DO_RELEASE(vSBS_Arry[nSBS_Indx],nBtn); } }Example of my axs (module)
BUTTON_EVENT [vSBS,0] { PUSH : { STACK_VAR INTEGER nBtn; nBtn = BUTTON.INPUT.CHANNEL; //fnDevMod_DeBug("'PUSH_CHNL-[',itoa(nBtn),'], SBS LVL-[',itoa(sSBS.sBrowseState.nLevel),'] :DEBUG<',ITOA(__LINE__),'>'",2); if(sSBS.sPlayer.nIP_ConState > IP_CLIENT_PENDING || nBtn == SBS_BTN_ONPAGE || nBtn == SBS_BTN_OFFPAGE) { // if(![vSBS,SBS_BTN_PROGRESS_BUSY]) // { STACK_VAR INTEGER nLVL; nLVL = sSBS.sBrowseState.nLevel; if(nLVL) { STACK_VAR INTEGER nRemote; LOCAL_VAR INTEGER nWarning_OK; //nIsPlugin = sLevel[nLVL].nType >= SBS_infoApps; nRemote = sSBS.sNowPlaying.nRemote; //_1_//fnDevMod_DeBug("'PUSH_CHNL-[',itoa(nBtn),'], LVL-[',itoa(sSBS.sBrowseState.nLevel),'] :DEBUG<',ITOA(__LINE__),'>'",2); CANCEL_WAIT 'AUTO_CLOSE_SELECT'; SELECT { ACTIVE(nBtn == SBS_BTN_PLY_PAUSE)://1 PLAY OR PAUSE, added double tap for stop { //moved to release } ACTIVE(nBtn == SBS_BTN_SKP_FWD || nBtn == SBS_BTN_SKP_BACK)://skip foward , skip back { STACK_VAR INTEGER nDoIt; SWITCH(nBTN) { CASE SBS_BTN_SKP_FWD: { ....... ....... HOLD[5,REPEAT]: { if(sSBS.sPlayer.nIP_ConState > IP_CLIENT_PENDING) { STACK_VAR INTEGER nBtn; nBtn = BUTTON.INPUT.CHANNEL; //_1_//fnDevMod_DeBug("'HOLD_CHNL-[',itoa(nBtn_Holding),'] :DEBUG<',ITOA(__LINE__),'>'",2); SELECT { ACTIVE(nBtn == SBS_BTN_SCN_FWD || nBtn == SBS_BTN_SCN_BACK): { nBtn_Held = 0; if(sSBS.sStatus.nMode == SBS_PlayMode_Play) { SELECT { ACTIVE(nBtn == SBS_BTN_SCN_FWD): { ..... ..... RELEASE: { if(sSBS.sPlayer.nIP_ConState > IP_CLIENT_PENDING)// || nBtn == UI_BTN_ONPAGE) { STACK_VAR INTEGER nBtn; nBtn = BUTTON.INPUT.CHANNEL; SELECT { ACTIVE(nBtn == SBS_BTN_PLY_PAUSE)://1 PLAY OR PAUSE, added double tap for stop { if(nBtn_Held == SBS_BTN_PLY_PAUSE) { fnBtn_DoCommand(SBS_PlayMode_Stop);So, main code:
Button_Event[dvTP,1] { Push: To[vdvModule,101] }And inside the module:
Channel_Event[vdvModule,101] { On: { // Do ramping start code } Off: { // Do ramping stop code } }I think I gravitated towards the button_event method simply because it can work exactly the same as if you had it in the main code if done correctly and I don't need to use timelines. Of course I don't think I ever thought of using a "to" with a push to work the channel ON/OFF, or even tried to see if that would work on a button event in a module instead of using do_push. In fact I really haven't used "to" for anything since my early days of programming and I have no idea why. Maybe it was "to" easy and I just felt the need to over complicate things.
