Home AMX Technical Discussion
Biamp Tesira Forte AVB VI response
Anyone having Tesira forte AVB VI's response strings for output volume control, level volume control,mute status etc.
I am working on a project where i dnt have access to a real device and for feedback i need those response strings. For command strings i am using Biamp command calculator.
Anyone having help file?
  • rynandorynando Posts: 68
    I just did a remote job with a Tesira where I had no access to the hardware prior to the installation and where I didn't have any control over the DSP's configuration. In the interest of time I used AMX's Tesira Duet module. I never use Duet modules for audio DSPs so this was a bit of a leap for me. It worked just as described in the docs. I was able to do all of the simple stuff; fader level and mute, calling presets, and controlling the VOIP dialers with ease and the feedback worked as expected. Anyway, after this experience, I would consider going that route especially if time is an issue.
  • tdewildtdewild Posts: 49
    // volume feedback
    ! "publishToken":"" "value":-18.900000<CR><LF>
    ! "publishToken":"" "value":-19.900000<CR><LF>
    ! "publishToken":"" "value":-20.799999<CR><LF>
    ! "publishToken":"" "value":-21.799999<CR><LF>
    ! "publishToken":"" "value":-22.799999<CR><LF>
    ! "publishToken":"" "value":-25.700001<CR><LF>
    ! "publishToken":"" "value":-26.600000<CR><LF>
    ! "publishToken":"" "value":-28.600000<CR><LF>
    ! "publishToken":"" "value":-30.500000<CR><LF>
    ! "publishToken":"" "value":-31.400000<CR><LF>
    ! "publishToken":"" "value":-32.400002<CR><LF>
    ! "publishToken":"" "value":-34.299999<CR><LF>
    ! "publishToken":"" "value":-35.299999<CR><LF>
    ! "publishToken":"" "value":-36.299999<CR><LF>
    ! "publishToken":"" "value":-37.200001<CR><LF>
    ! "publishToken":"" "value":-38.200001<CR><LF>
    ! "publishToken":"" "value":-39.200001<CR><LF>
    ! "publishToken":"" "value":-40.099998<CR><LF>
    ! "publishToken":"" "value":-41.099998<CR><LF>
    ! "publishToken":"" "value":-42.099998<CR><LF>
    ! "publishToken":"" "value":-43.000000<CR><LF>
    ! "publishToken":"" "value":-44.000000<CR><LF>
    ! "publishToken":"" "value":-45.000000<CR><LF>
    ! "publishToken":"" "value":-45.900002<CR><LF>
    ! "publishToken":"" "value":-46.900002<CR><LF>
    ! "publishToken":"" "value":-47.900002<CR><LF>
    ! "publishToken":"" "value":-48.799999<CR><LF>
    ! "publishToken":"" "value":-49.799999<CR><LF>
    ! "publishToken":"" "value":-50.799999<CR><LF>
    ! "publishToken":"" "value":-51.700001<CR><LF>
    ! "publishToken":"" "value":-52.700001<CR><LF>
    ! "publishToken":"" "value":-33.400002<CR><LF>
    // Mute feedback after request
    +OK "value":true<CR><LF>
    +OK "value":false<CR><LF>
