Toggle navigation
Categories
Discussions
Sign In
Home
NetLinx Studio
Module File
Frankie
71
June 2004
in
NetLinx Studio
Ok
I want to write a Module file. Can I do that with out writing the user interface part?
[Deleted User]
June 2004
Yes. The UI's that AMX writes for their modules is to give you a starting point for working with the COMM modules. Also gives you the flexibility of changing channel codes.
Joe Hebert
2,159
June 2004
Frankie,
If you haven?t already seen these yet, here are two tech notes with module source code example zip files that you may want to check out:
Tech Note 271: Module Example
Tech Note 375 How to Write Your Own Netlinx Modules
Have fun!
Joe
Sign In
or
Register
to comment.
Have fun!
Joe
