Setting Baud Rate
sonny
Hello...
I am working on a serial protocol and am having trouble setting the baud rate on an internal serial port on an NI3000. I have the SET BAUD command in the [DEFINE_START] section of the main program file. I do a GET BAUD from the "Control Device" utility and it shows 38400 even though I have it set to 4800. I can execute the SET BAUD from "Control Device" and it sets the port up properly.
I assume [DEFINE_START] isn't the place to put this, but putting in a conditional in the mainline seems kind of sloppy.
Any ideas/advice?
Thanks...
Any ideas/advice?
Thanks...
I would also put the command in the Online Event for the device.
I thought I had seen a tech note as well but couldn't find it. I moved the code to a module and added it to the ONLINE event and all appears well.
Sonny
example:
data_event[device]
online:
send_command device,'SET BAUD 9600,N,8,1'
I'm not too familiar with how the NI3000 works internally, but my guess is that the DEFINE_START is executed before the serial ports, etc come online. So basically it sends SET BAUD to the serial port, _then_ starts up the serial port, which probably resets the baud to 38400. This is just my speculation, but looking at the [msg on] messages when I boot my unit it seems like devices come online after a little while.
/Hakan
Yes the best place to SET BAUD and to set RS-232 setup for unit is to have in the online of data_evend like above. The NI-XXXX devices came online after a little.
Maybe security is more important to start first.
Bogdan
Sonny
