TPDesing 4 Paste to multiple buttons.
bogdan
Has anyone else seen this..... If you select more buttons and from Button Properties try to change for all (buttons) Channel Port or Paste something like Fill Color, Bitmap, Font ?? only the last button selected gets changed and the other buttons remains the same.
I will like to change Properties for selected buttons .
I am using TPDesign 4 ver. 2.3.Built 319 under Win XP.
Previous I had an older Laptop with Win 98 , TPDesing 2.2 and this was working fine.
There is any setup in TPDesign 4 for this?
Thanks.
Thanks.
This allows you to apply changes to all the buttons you have highlighted.
Works this way.
With 'Apply To All' off, operation is much like that in TPDesign3, where you and use Prev and Next to cycle through the selected buttons and set their properties individually. But here's a "power-user" tip for using this in conjunction with TPDesign4's Quick Input feature (found in the Edit->Quick Input menu). Let's say you want to set the channel codes for all the buttons on a page, but don't want to use Power Assign because you have specific codes that you need. First select the buttons that you want to set and ensure 'Apply To All' is on (Ctrl+Shift+A). Next, set the Channel Port property in the Programming tab to give them all the same port number. Next, select, but don't edit the Channel Code item. Turn off 'Apply To All' (Ctrl+Shift+A), and set your Quick Input to Current Property. This will cause your keyboard input to go directly into the Channel Code property. Plus, you can use Alt+Left and Alt+Right to navigate through the selected buttons. So, with a minimum of keystrokes, and with your hand never leaving the keyboard, you can set the channel codes for all the buttons on a page.
