RS232 control of Bose Lifestyle
Hi there,
has anyone controlled Bose Lifestyle systems by RS232? There's a rumor that it's somehow possible, but no facts. It seems that Cr*****n has a solution.
Thank you for any comments.
Best regards,
Best regards,
Yep you can control it from AMX also, as there is a very tiny jack connector on the backside of some models from Bose. The one that have it can be controlled through RS-232. The protocol is not very efficient (volume control is only step by step and not fluent) but it's better than nothing !
If you don't find the protocol I should be able to find it for you if you have few days.
Vinc
I'm also interested in the protocol.
we are happy about any information you can get. Thank you very much.
Marc
Thanks.
Hello Ray:
The serial port jack on the back of the system is used by Bose technicians to get certain computer read outs on the system when a technician is doing a repair.
This port is not for use by end consumers and cannot be used to interface with an AMX Landmark system. There are no protocol commands available.
Regards,
Thank you for contacting Bose Corporation.
Kevin Bradley
Product and Technical Support Team
Bose Corporation
US Telephone: (800) 367-4008
International Tel: (508) 766-1900
Email: http://www.bose.com
Fax: (508) 766-1919
Telephone Hours: Mon-Fri 8:30AM-8:00PM, Sat 9:00AM-3:00PM (EST)
Walk-In Hours: Mon-Fri 9:00AM-5:00PM
This is how i managed to control the E4 business music system with AMX even though Bose said it wasn't possible...
Let me know!
[edit] it seems that C******* has restricted downloading of macros's to dealers only, sorry. If you really need it then i can call in a favour....
Pin 2 (AMX) -> 2 mini Jack
Pin 5 (AMX) -> 3 Bose
For the command see attack file.
Hops this can help
Fabrice, ACE
If you need it let me know...
This is the complete data sheet for bose lifestyle protocole.This is not confidential as they says
eg .
SEND_STRING dvBOSE, "'KP %26',13" //key press simulation for volume up
SEND_STRING BOSE, "'VS %',ITOA(Vol),13" //direct value
If not, does anyone have the protocol for that system?
This works for me. Tested!
Command -> Function
MM 4a,41,01 -> Power On
MM 4a,43,01 -> Power Off
MM 42,40,01,02 -> Room A Source CD
MM 42,40,02,02 -> Room B Source CD
MM 42,40,04,02 -> Room C Source CD
MM 42,40,08,02 -> Room D Source CD
MM 42,40,01,01 -> Room A Source FM
MM 42,40,02,01 -> Room B Source FM
MM 42,40,04,01 -> Room C Source FM
MM 42,40,08,01 -> Room D Source FM
MM 42,40,01,03 -> Room A Source Aux
MM 42,40,02,03 -> Room B Source Aux
MM 42,40,04,03 -> Room C Source Aux
MM 42,40,08,03 -> Room D Source Aux
MM 42,40,01,04 -> Room A Source Video 1
MM 42,40,02,04 -> Room B Source Video 1
MM 42,40,04,04 -> Room C Source Video 1
MM 42,40,08,04 -> Room D Source Video 1
MM 42,40,01,05 -> Room A Source Video 2
MM 42,40,02,05 -> Room B Source Video 2
MM 42,40,04,05 -> Room C Source Video 2
MM 42,40,08,05 -> Room D Source Video 2
MM 42,40,01,06 -> Room A Source Tape
MM 42,40,02,06 -> Room B Source Tape
MM 42,40,04,06 -> Room C Source Tape
MM 42,40,08,06 -> Room D Source Tape
MM 44,41,00 -> Room A Vol +
MM 44,42,00 -> Room A Vol -
MM 43,41,01 -> Room A Mute
MM 43,40,01 -> Room A Unmute
MM 44,41,01 -> Room B Vol +
MM 44,42,01 -> Room B Vol -
MM 43,41,02 -> Room B Mute
MM 43,40,02 -> Room B Unmute
MM 44,41,02 -> RoomC Vol +
MM 44,42,02 -> RoomC Vol -
MM 43,41,04 -> RoomC Mute
MM 43,40,04 -> RoomC Unmute
MM 44,41,03 -> Room D Vol +
MM 44,42,03 -> Room D Vol -
MM 43,41,08 -> Room D Mute
MM 43,40,08 -> Room D Unmute
It is working for me. Tested
Command -> Function
MM 43,40,01 ->Room A Unmute
