netlinx NLDiagsPgm
Hi everyone,
I just had a very odd issuse when using NLDiasPgm. I was trying to reset the Netlinx system to the correct time and everytime I tried to verify after using the 'set time/date' it kept showing up AM instead of the PM I had set it to. I logged onto the system using Studio 1.* and got the correct time when I used the 'get time/date' function. I went back to the NLDiagsPgm and it still shows the correct time but AM instead of PM. I have all the AMX systems on campus programmed to shutdown and lock-out from midnight till 6 AM. Needless to say the Prof was a little upset. Has anyone else had problems with NLDiagPgm not refreshing data properly?
  • Something odd; I just tried was to monitor the NLDiagPrm while changing the system time using the TP. It only would change to PM after 13:00 hrs before that it remains AM. Seems like a bug in the program code.
  • Date/Time Set Problem
    I'll look into this problem for the next release of NLDiagPgms. Question: What model of the NetLinx master did you have the problem with?
    Thanks.
    It was a NXI with a ME-260.
