SX20 Module controlled via USB to Serial
Hello,
Has anyone used a USB to Serial cable and the AMX Module to control a Cisco SX20?
I couldn't get any comms when using USB to Serial Cable(s).. i tried 3... to any NI Serial Port
Are there any settings on the SX20 perhaps?
Any help would be great.
In the end i used IP control.
Cheers,
Ant
Cheers,
Ant
If it's a fresh unit that you have setup, then security may not be the issue, but if someone else has been the admin, they may have locked the unit down.
Also, I found that having too many conductors on the serial cable may create a hardware hand shaking flow control lock. Rebooting the controller seems to be required if that occurs. Just use a three conductor serial cable to avoid this issue.
But yeah, go IP if possible.
We always use serial to control codecs, so I do know the Cisco C and SX series always require the steps of going into the admin menu to the SerialPort section and turning LoginRequired to off (the alternative is to bake the default SerialPort login credentials into your code).
One note, after connecting the dongle the codec requires a reboot to recognize the device (I presume like a PC, it has to load the driver but only does so when it sees the new device at startup). Other than that it's been reliable over RS232 at 38400.
Hope this helps and best of luck.
Larry
I didn't recall, but was told we'd tried another generic adapter with no luck, hopefully this helps steer you towards a solution.
LL
Thanks again
