communication between controllers
MorgoZ
Hi,
i need to make some controllers on a project to communicate between them, to do so i'm thincking in opening sockets (with IP_CLIENT and IP_SERVER) in each controller and send messages throught them, but first i want to ask you for a better approach if there is any.
Thanks for your help!
In the Netlinx Help File check out the M2M (Master-to-Master) section. It might be within the spectrum of your use-case.
https://youtu.be/-a9C7UxBXXI
HAHAHA!
Actually, as some of you may know, my other life apart from this stuff is I have been a music producer and audio engineer for many many years. I've produced a lot of music in the indie world and have sang and played on a lot of records. I also run a record label (http://www.tremulant.com) and do my own music as well. But most people don't know what I look like (thankfully) the most common comment I get when people do finally see me is just that: "I am really surprised by what you look like." So, I'm used to disappointing people.
Salutes!
http://www.manualslib.com/manual/395216/Amx-Netlinx-Programming-Language.html?page=107
I finally got 'round to making the 2nd part of the M2M video. Not that it will help anyone here...
https://youtu.be/UAr6ssUNt9A
