TPDesign 3 -> NI-3000 -> AXLink panels
amxhobbyist
Group,
I recently discovered a new caveat from upgrading to Netlinx. I'd been using an Axcent3 and upgraded to an NI-3000, switching the Axcent3 to slave mode. I am still using my older AXLink touchpanels.
How do I download to my panels this way?
TPDesign refuses to connect via the "axlink" option. I can connect to the Netlinx master via RS232 just fine, so it's not my connection. My guess is TPDesign is looking for something in terms of an AXLink master that the NI-3000 isn't providing.
Is there a workaround? Or am I doomed to drag the panels over to my computer and do it via straight RS232 every time I want to change something?
Thank you for any advice you can give me.
You need to add the touchpanel files to the Studio project and then map them to the appropriate address. Then use the file transfer dialog to download the panel files. When downloading you have the option to included the bitmaps, fonts, icons or not which is accessed through the options dialog in the file transfer window.
By the way it's way quicker when downloading source code to connect to the master via TCP/IP rather then RS-232.... for touchpanel files it doesn't really matter as it gets limited by the speed of the axlink bus.
In my book, half as slow is extraordinarily slow. In some things, I guess I'm not very patient.
Ah, I got it. Didn't know I could do that. Thanks for the info & instructions.
Agreed, and I am connected to the master via TCP/IP; however, since TPDesign3 only supported RS232, I tried it that way. I've always just loaded my panels from TPDesign when the Axcent3 was the master.
As for the speed, yeah, axlink is slow, but it's not that big of a deal as I rarely change panel configs. I'm just happy to be able to transfer my source code instantly, since that gets changed much more often. Transferring source to the Axcent3 over and over again when testing a new routine was painful.
