The Massio ControlPad does allow for ethernet control of devices. The ControlPad is configured via AMX RPM and Dynalite is a supported lighting product. I built a test project with an 8 button ControlPad and could assign a different preset to each button or combine elements in macros. You can investigate this further at my.amx.com
I investigated the lighting system preset - not a video conference preset. While VTC is a supported device and you can use macros to dial a specific number, I would highly encourage you to investigate your specific system requirements by building out the RPM project. It only takes a few minutes to accomplish and you will know with certainty if this hardware/software combination is what you are seeking.
