RMS SDK 4.3.17 is corrupted
This SDK 4.3.17 has a corruption in the CUSTOM_EVENT's CUSTOM.ENCODE string.
When you use STRING_TO_VARIABLE on this version you will get an CIpLibrary::String_To_Variable - Error -1.
Which is " -1 = Decode variable type mismatch" and that gives me the conclusion that the string in the custom_event created by the RmsNetLinxAdapter_dr4_0_0.jar is corrupt.
Use the previous SDK 4.3.12 until another release fixes this.
  • ericmedleyericmedley Senior Member - 3709 Posts Posts: 4,141
    Thanks for letting us know!
  • RMSDevRMSDev Junior Member Posts: 7
    Hi there Dennis,
    What is your character encoding set to? Which structure is being decoded when you see this error message?
    Thanks!
  • tadem2ktadem2k Junior Member Posts: 4
    I also get this message after upgrading to 4.3.17 when pulling scheduling information via API command, specifically when RmsEventSchedulingBookingResponse function being called.
    Try executing these commands back to back when the RMS client comes online as a temporary work around until a fix is available:
    SEND_COMMAND vdvRMS, 'CLIENT.CHARSET-UTF-16BE'
    SEND_COMMAND vdvRMS, 'CLIENT.CHARSET-DEFAULT'
    This fixed it for me, thanks
  • AvargasAvargas Junior Member Posts: 56
    Thanks for the info, I was mad with this thinking that the problem was any recent change in my code.
  • Dennis E.Dennis E. DeTeK AB Posts: 24
    The SDK 4.3.17 issue which I had was an update issue (going from the previous to a newer), probably the one which RMSDev had the solution too.
    I fixed it with erasing the masters completely and start fresh.
    There is a bug when there are no bookings in current month.
    (19:28:55.731):: Command To [41001:1:1]-[?SCHEDULING.BOOKINGS.SUMMARY.DAILY-06/5/2015,2]
    Will return nothing except in the diagnostics window
    (19:28:56.117):: 2015-06-06 19:28:56,748 ERROR [Timer-0] com.amx.rms.client.netlinx.adapter.result.impl.Sch edulingBookingsSummaryDailySuccessHandlerImpl - run(): dailyCount is null
    I've got a JIRA ticket in devs on this and I've recieved a test pre update which fixes this issue.
    New version is going to be released rather soon of what I've heard.
    Also good to know is there are specific NI (4.3) and NX (4.4) releases of RMS SDK.
  • pdabrowskipdabrowski Aussie Guy Posts: 184
    Dennis E. wrote: »
    Don't do what I did and neglect to update Studio, I grabbed the 4.4 SDK for the NX masters and got major compile errors because I was running on an old version of NS4 that didn't play nice with the new SDK. Namely "rmsclient is not a valid module type" even when I didn't declare that jar as a module in my code.
    ​I can report that RMS SDK NI version 4.3.23 is working find.
