No compiler error? The second switch is with in the same brace as the case's.
vining
DEFINE_FUNCTION fnJSON_Process_Actions(CHAR iAddAction[],CHAR iAction[],CHAR iObjTag[],CHAR iCopy[],INTEGER iFBIndx)
{//note iCopy is already a copy duh
STACK_VAR INTEGER i;
STACK_VAR INTEGER nLVL;
STACK_VAR _FB_Single sMyFB;
STACK_VAR INTEGER nRecognized;
nRecognized = 1;
nLVL = sSBS.sBrowseState.nLevel;
sMyFB.cTopTag = iAddAction;
sMyFB.cTag = iAction;
sMyFB.cObjTag = iObjTag;
WHILE(find_string(iCopy,'":',1))
STACK_VAR INTEGER nFBS;
sMyFB.cFB_Tag = REMOVE_STRING(iCopy,'":',1);
sMyFB.cFB_Tag = fnJSON_TrimLeadChars('"}{[,',sMyFB.cFB_Tag);
sMyFB.cFB_Tag = fnJSON_TrimEndChars('":',sMyFB.cFB_Tag);
SWITCH(iCopy[1])
CASE '"':
GET_BUFFER_CHAR(iCopy);
nFBS = find_string(iCopy,'"',1);
if(nFBS)
sMyFB.cFB_VAL = GET_BUFFER_STRING(iCopy,nFBS);
sMyFB.cFB_VAL = fnJSON_TrimLeadChars('"',sMyFB.cFB_VAL);
sMyFB.cFB_VAL = fnJSON_TrimEndChars('"',sMyFB.cFB_VAL);
CASE '{':
nFBS = fnJSON_FindEndTag(iCopy,'{','}',1);
CASE '[':
nFBS = fnJSON_FindEndTag(iCopy,'[',']',1);
DEFAULT://an interger?
STACK_VAR INTEGER n;
nFBS = 0;
for(n=1;n<=10;n++)
if(iCopy[n] >= '0' && iCopy[n] <= '9')
nFBS = n;
else
BREAK;
if(nFBS)
sMyFB.cFB_VAL = fnJSON_TrimEndChars('",',sMyFB.cFB_VAL);
SWITCH(sMyFB.cFB_Tag)
CASE 'cmd': {sLevelList[nLVL].cCmd[iFBIndx] = sMyFB.cFB_VAL;}
CASE 'params': {sLevelList[nLVL].cParams[iFBIndx] = sMyFB.cFB_VAL;}
DEFAULT:
nRecognized = 0;
fnJSON_DEBUG("'Process_Actions, !!, AddAction-[ ',sMyFB.cTopTag,' ], Action-[ ',sMyFB.cTag,' ], FBTAG-[ ',sMyFB.cFB_Tag,' ], VAL-[ ',sMyFB.cFB_Val,' ], FBIndx-[ ',itoa(iFBIndx),' ] :DEBUG<',ITOA(__LINE__),'>'",3);
if(length_string(iCopy))
fnJSON_DEBUG("'Process_Actions, ERROR, AddAction-[ ',sMyFB.cTopTag,' ], Action-[ ',sMyFB.cTag,' ],DUMPING-[ ',iCopy,' ], FBIndx-[ ',itoa(iFBIndx),' ] :DEBUG<',ITOA(__LINE__),'>'",1);
if(nRecognized)
fnJSON_DEBUG("'Process_Actions, $$, AddAction-[ ',sMyFB.cTopTag,' ], Action-[ ',sMyFB.cTag,' ], FBTAG-[ ',sMyFB.cFB_Tag,' ], VAL-[ ',sMyFB.cFB_Val,' ], FBIndx-[ ',itoa(iFBIndx),' ] :DEBUG<',ITOA(__LINE__),'>'",3);
nRecognized = 0;
Button_Event[dvaTPs,nButtons] { Push: { Stack_Var Integer nTp nTp = Get_Last(dvaTPs) Switch(nTp) { Case 1: { send_string 0,'one' } Case 2: { send_string 0,'two' } send_string 0,'infinity' } } }
