division not returnig float
MorgoZ
Hi,
I don't know why this operation returns an integer value and not a float:
The last line returns "0" when it should be "0.3". Does enyone can explain why is it being rounded to an integer?
Note: "real" comes from a level value
Thanks!
DEFINE_FUNCTION char[10] DbsIORealToFake(char cTipoIO, float real) { stack_var float fAux integer nAux, nAuxTp, nAuxFake nAuxTp = MAX_LEVEL_TP - MIN_LEVEL_TP if(real > MAX_LEVEL_TP) real = MAX_LEVEL_TP if(real < MIN_LEVEL_TP) real = MIN_LEVEL_TP fAux = (real - MIN_LEVEL_TP) / nAuxTp send_string 5001:0:0,"'fAux ',ftoa(fAux)" }
Thanks!
Now you have float = (float - float) / float which should return a float type. I have also heard, but not tried, that simply adding and then subtracting 0.1 to the equation will cause the compiler to return a float as follows:
e.g.
At the end of the function you need:
RETURN ftoa(fAux)
Then char[10] will be something else, it will be nothing
Thank you both!
